K0UA (which looks a whole lot like a FCC station ID) is right. Antenna theory is extremely complex and antenna manufacturers use the complexity along with their version of snake oil and marketing to confuse the consumer and sell their products. They use terms like dBi to make you think you are getting something you are not. Throw in some misnomers like 'antenna tuners' which do nothing to tune your antenna, rather they make your non resonant antenna acceptable to your radio (and turn your signal into heat) and you have a recipe for a radio that doesn't radiate much power. The manufacturers sometimes hide the fact that a vertical antenna has 2 parts, the vertical element they sell and the other side of the vertical element which is just as important, the ground plane, which is generally your vehicle. As noted above, whenever you shorten an antenna, you are compromising something, usually radiated power and bandwidth.
