Towing heavy on a 1/2 ton
/ Towing heavy on a 1/2 ton #51
Of course, that doesn't take into account the wear/tear on the truck.. And that could be substantial.
And maybe I missed it, but what about the value of your time? Even if you don't want to put a dollar value on it, what else could you be doing? What is that worth to you? If nothing, ok then. But my time is worth quite a bit to me. You do realize that they stopped making it, right?
/ Towing heavy on a 1/2 ton #52
Nope they keep making it every millisecond of every day. I kind of doubt I'll be able to consume more than a finite amount though.
/ Towing heavy on a 1/2 ton #53
We need sawdust for our horses. Sometimes we know someone that does it, but it's getting harder and harder to find someone.
Options - get it ourselves..so shovel it off the truck...can borrow a friends dump trailer, but it has no tall sides and sawdust is a bulky item, not heavy. We can do the trips..but our time is preciouse as we have so little of it. And to get enought we'd have to make 4 trips - 5 to 6 hours, plus unloading in the barn if we have to shovel becomes unpleasant, both in time and physically. I'd much rather do most anything else.
We can hire a guy - get 10 yards in the barn, $200. We'd like more sawdust than that to get thru the winter.
We can hire a guy with a triaxle dump - won't fit in the barn (OH BOY!! Tractor tiem!!) and get a LOT of sawdust - we want 12-13 yards, $100 for the sawdust and he wants $100 to deliver it.
We could rent a dump truck..$375 a day. Makes no sense.
Buying a dump trailer, building sides, etc makes no sense either.
When you factor in time, gas, etc - let someone else fetch it.
As for 300t of gravel - ifyou're buying that much many places will cut you a deal - free delivery or lower price per ton that offsets that delivery fee.
/ Towing heavy on a 1/2 ton #54
I have a dump trailer and live <15mi from the quarry, I have my gravel delivered 20t at a time unless i only need 5t or less. It's just not worth my time and the wear and tear on the truck and trailer honestly.
I've never had a situation where I had too much gravel, so I just get 20t every time. Call up the quarry and tell them how much I need and they have my card on file, if I call in the morning its typically delivered later that day.
If I have to make more then 2 trips its typically not worth it to me to use my equipment.
/ Towing heavy on a 1/2 ton #55
Some friends were into barrel racing when their kids were growing up so they kept 5 horses, and occasionally a couple for friends. They had an older F700 with an enclosed body that they would use to haul hay every year; then they would bring it to a saw mill where the guys would blow shavings into it, then call when it was full. It worked great for both parties and reduced the amount of handling.
/ Towing heavy on a 1/2 ton #57
If/when that works, I love it. But businesses run every day. Did they have a roster of other F700s to call on and be there when the full one pulled out?
We are a wood shop and produce a 53' trailer of kiln-dried wood dust/shavings/chips every 1-2 weeks. There is no way we would count on a random assortment of farmers who may or may not need "shavings" at any given time. We did that for many years, and it was a constant hassle. With our current arrangement, we call someone the day before we need the trailer changed out, they bring a new one, swap it out, AND pay us around $20/ton (I don't recall the exact current amount, but it's generally around $250 per load) for the pleasure. They take it back and turn it into $250/ton pellets. That's what I call win-win.
/ Towing heavy on a 1/2 ton #58
You are looking at it from the other end of the spectrum. I was just commenting on what worked for them, and seemed to work for the mill, also.
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
MGY Shop Heater (A60463)
MGY Shop Heater...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2007 LAREDO 5TH WHEEL (A60736)
2007 LAREDO 5TH...
