Camera Security Systems???
/ Camera Security Systems??? #41
Yeah, I run their gear for all my network stuff here, professional quality gear at prosumer prices. As far as I know they're also the only ones to offer mobile app access without a monthly subscription since all their stuff uses WebRTC for p2p connections (at least on the unifi side).
I ended up not going with them since they didn't do monitoring as well but they were a serious consideration.
Vivotek's cameras have a free app for iPhone and android devices.
/ Camera Security Systems??? #42
From their website for VAST(which I assume is their central management software) states:
"Web Access via Internet Explorer"
Which doesn't give me a whole lot of confidence ;).
/ Camera Security Systems??? #43
Actually, there are many cameras that only work in IE primarily because the Windows Media Player plugin only works in Internet Explorer. To use anything else requires users to learn to install codecs, plugins, or other addons.
If a user is going to install anything, they should install the VAST software, which is some of the best software available for any system.
The server side of VAST stores all the video from all the cameras in a SQL database, making searches super simple and fast. I can do a search on my cameras and tell you how many people have been in and out of my driveway over the course of a week and the search takes about five minutes.
Check it out:
100% free (with the purchase of a camera) and no limits on the number of cameras. iViewer for Android and iPhone are very nice (and free) as well.
/ Camera Security Systems??? #44
I have the amcrest 960h from amazon. Works good. Had it for more than 2 years. The way my house is designed, it was an absolute ***** to run the bnc and power cords.
What sysop is talking about sounds better.
/ Camera Security Systems??? #45
From all of the different brands mentioned it seems like there is no consumer market leader?
/ Camera Security Systems??? #46
I don't think the self installed consumer market is big enough to have a clear leader given the number of contenders.
Three of mine are Pan-Tilt-Zoom so I can look around when I want to. Most of the ones mentioned above are probably fixed view, but posters haven't mentioned that. Mine were meant for indoors, so I had to modify the housings. Outdoor PTZs are common now, but cost more, generally over $100 each.
/ Camera Security Systems??? #47
I installed cameras at my shop. I had multiple companies quote the job and pricing was all over the place so I looked at DIY systems and ended up buying a from SCW
Link was supposed to go here
I have no complaints. I had trouble setting up a few cameras that needed to be powered through a remote switch but their tech people walked me through it. One camera had issues and they sent out a replacement
/ Camera Security Systems??? #48
I have an 8 camera 1080p Lorex System with a DVR and a 1tb hard drive. I can monitor and play back right on my phone. Don't get anything less than 1080p cameras because the video sucks. These are wired cameras with BNC Cables. This system will also send you e-mail alerts when motion is detected. But that could be a bunny in the back yard. Lorex has their own app called FLIR, doesn't use a web browser and works great.
/ Camera Security Systems??? #49
Bunnies, HA! Motion detection on cameras mostly sucks in outdoor environments. A cloud passing over the sun or the wind rustling the grass will trigger motion alerts. If you have time, patience, and your camera has the options, sometimes you can set a specific part of the field of view and the sensitivity levels to minimize false alerts (the Vivotek cameras I recommended have such settings).
/ Camera Security Systems??? #50
Yep, you change change the sensitivity and field of movement with Lorex also
/ Camera Security Systems??? #51
You can do that with most that I've seen. But none of them can account for a spider, wasp, bird or similar. One of mine has the front road in view, so traffic could trigger it. Reasons why I don't have motion or alarm set on any of them.
/ Camera Security Systems??? #52
For motion detection, I use real motion detectors with "pet aware" logic built in so they don't go off at every tiny movement. They're wireless ZWAVE based motion detectors, I use a Universal Devices controller. I have programs set to alert me on low battery, loss of signal, and motion. In the programs, they pull camera stills and include them with the message.
/ Camera Security Systems??? #53
Yeah my Reolink cameras can be set for specific motion area and sensitivity. My biggest problem has been spiders. I have to spray my outdoor cameras every few days to keep spiders from getting in them. They absolutely LOVE to climb back and forth over the lens and build just enough web to make them record constant. At night the bugs flying keep them recording in the summer. Set the sensitivity too low and the deer can walk right by but NO setting prevents recordings of bugs and spiders.
Those Vivotek cameras sound pretty pricey and don't look all that impressive.
My Reolink cameras have a wifi distance of 300 ft or so. I have the quality set DOWN to 1080P. Mainly because windows media player doesn't recognize the higher resolution they are capable of. The RLC 411WS model I have doesn't have sound or pan and tilt but they make models that do. By the time I bought and set up two cameras on a 100W solar panel and deep cycle battery I was in for a little under $400.
Here is an image capture from one of my cameras.
Here is a sample video.
/ Camera Security Systems??? #54
This is one area where Arlo shines. Since the camera is not rolling 24/7 (it stays dormant to conserve battery life), the motion detection is not based on frame-by-frame image comparison as most camera motion detection algorithms are. The camera has an embedded PIR sensor, which is what turns on the camera, establishes a connection to the base station, and starts streaming data to the cloud (in the blink of an eye). A PIR sensor is much better about false positives. It senses changes in heat; like an ultra-simple thermal camera. So in order for something to trigger the Arlo, it has to have body heat. Shadows, rustling leaves, none of that sets off the camera. I have had wasps set it off, when they buzz right in front of the camera for long enough, but it's not common.
I'll chexk out Lorex.
I actually have little use for motion detection. Can't use it,in the shop because Willard (dog) lives in there. He has access to outside thru his own door so would constantly trip the outdoor cameras as well. Then throw in the constant flow of wildlife thru the area and I think they might become a nuisance.
My primary expectation would be to record activity that I could refer back to if I was robbed for example. Is motion detection needed for that?
Secondary use would be for Terry to view the property before entering when coming home at night or after being gone for awhile.
What other benefits am I missing?
/ Camera Security Systems??? #56
I personally wish they would remove the word "security" when used with cameras. I mean, as far as joe blow public goes.
You don't want to get robbed, that's what REAL security is about. Having footage after you have been robbed is quite useless in my way of thinking, and certainly not security at all.
Obviously a camera isn't going to prevent robbery. It's going to do little to discourage it. Daily news stories of robberies include camera footage.
I live in a sparsely populated county. My hope would be that my friends and neighbors could look at the pics and help me locate the offender. Just to visit.
/ Camera Security Systems??? #58
That is what I have. The fox video I posted in another thread here came off one of my cameras.
/ Camera Security Systems??? #59
IF it does discourage a crime, then really a fake one will work equally well. Actually, I prefer real, but defective ones! I have been in the security bus for almost thirty years. I sell camera systems to institutions and business where they are useful. I sell door intercoms with cameras that are useful. I won't sell residential camera systems, because I find them misunderstood and for the most part useless in preventing crime against my customers, and THAT is my business.
/ Camera Security Systems??? #60
Go smash your hand with your biggest hammer. It will cause less pain then the Amcrest setup.
To the OP- the 兎asiest cameras work with WiFi. Once you get good WiFi to the areas that you want cameras their are several choices. I tried several that didn稚 work as advertised. I settled on the iSmart cameras. They are indoor cameras but I can look through the windows.
I have AmCrest. At first, I loved it. Very nice out-of-the-box setup and kit included 2 real long + 2 60' cables so nothing extra needed to buy (except monitor, but had an old one to re-purpose). Setup was super easy and just downloading their app from google playstore then scanning the QR code on box had it working on my phone. 100x easier setting everything up and having it running than I thought it would be. Very good picture quality for inexpensive cameras on BNC cable. Included HDD holds about a week's worth of 4 cameras recording 24/7 (not using motion detect).
Then the box started to make a racket. Investigate and the fan was chewing into its housing. Was an odd size like 50mm (can't remember exactly) but had to special order since none of the typical PC sized fans I had in pile of old computer junk were right. But simple fix.
Then one camera started only working intermittently. Then barely, then not at all. Turns out it is the connection at the box. Something wrong there that I figured was a broken solder I could easily fix, but no luck figuring it out. Wiggling that connection makes the camera work. But otherwise, it just displays black. No idea what caused tat to fail - not like I move the box around and once set up, never moved the cables around. No stress on the cables pulling on that connection.
So I went from an AmCrest fan to "never again"....oddly that change in attitude toward the brand happened right after warranty was up :) That's as long as it worked right.
But we did have some people going through neighborhood breaking into cars and was able to give local PD a thumbrive with excellent HD pictures of their faces. So although some problems and it only 75% works after a couple years, when I did need recorded footage from it, it was there and fairly easy to retrieve and download.
The phone app.....when it works, its great. Only works half the time though. Might be the app, the system, my phone, or my wireless router. No idea why it sometimes chooses to work or not work. But is kinda cool to be away from home and see everything at the house.
For my remote property (no utilities, no internet), I use Moultrie A30i trail cameras. Not the best cameras, but I like the Moultrie steel lock boxes that fit those that can be secured with a Python cable, regular padlock, or both. The "i" versions (A-30i, A-40i, etc) don't have red glowing lights at night so don't give themselves away. They work pretty well and i just have several scattered but overlooking each other along with watching their designated areas. For that application, I'm pretty happy with their performance. No sensitivity setting so LOTS of pictures of tree branches blowing in the wind, but that's only complaint. Great pic quality even at night and last a long time on the inexpensive Amazon Basic brand AA batteries.
2014 International 4300 DuraStar Crew Cab Knapheide Utility Flatbed Truck (A68183)
2014 International...
525 Gal Supply Tank (A64912)
525 Gal Supply...
Rears PT 1000 Gal Orchard Sprayer (A64911)
Rears PT 1000 Gal...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
(2) 38" Tractor Rims (A64912)
(2) 38" Tractor...
