New truck #@$%@#&
/ New truck #@$%@#& #322
I was sure that thing had been sitting on a flat bed and fell off. When you see a frame like that, it makes me think how retarded that is that we use such a massive device, often to transport one or two people! I just hope, the thieves perished in that wreck.
/ New truck #@$%@#& #323
They didn't, according to the link provided.
/ New truck #@$%@#& #324
That's too bad. I guess, Only the good die young, as the song goes.
A bodyman told me a little while ago, what a survivable vehicle my 08 Duramax was.
/ New truck #@$%@#& #325
Per... that truck was going around 100MPH (stolen, in a police chase) when the driver lost control spun around and hit a Camaro going ~50MPH in the other direction with the truck's rear bumper.
With a 150MPH closing speed and a rear end collision, I am not surprised.[/IMG]
But... have you ever, in the 100+ years of cars traveling a 100+ MPH, seen that, until now?
/ New truck #@$%@#& #328
That is the first 150 MPH closing speed rear end collision with a stock body on frame truck that I have seen.
Aaron Z
/ New truck #@$%@#& #329
Aaron Z
What does "closing speed" mean? And how does it have any real life application? IOW, how do two vehicles (of equal mass) hitting each other head on at 100 mph differ from one vehicle traveling at 100 mph hitting a bridge abutment?
/ New truck #@$%@#& #330
50% more force coming at you than hitting a stationary object.
/ New truck #@$%@#& #331
I would have said "combined speed". If you ever see the footage of aircraft striking a concrete barrier in time lapse, I would guess hitting an immovable object is worse than hitting a moving object given the same speed deferential.
/ New truck #@$%@#& #332
It DEPENDS. Force = Mass x Acceleration
Deformation, or energy absorption, comes into play for figuring collision forces, but that's a bunch more math...
/ New truck #@$%@#& #333
It depends. On a lot of factors.
Compared to hitting an immovable object, for the force to be greater, the other object has to be larger and/or moving faster than you AND have a fairly rigid form factor. Just as an example, if you're driving your 2018 aluminum body F150 at 100 mph and hit a tumbleweed traveling in the opposite direction, also at 100 mph not much will happen. Or, say that instead of a tumbleweed, pretend that someone invented a 5000# marshmellow that somehow got to 100 mph. That's taking it to extremes, but doing so proves the point. It's not just speed, it's also mass and form. And that's why hitting an almost unmovable object (such as a bridge abutment) is going to generally have the same effect as hitting a similar vehicle at the same speed coming from the opposite direction.
/ New truck #@$%@#& #334
The scenario i responded to was 2 vehicles coming at each other.
/ New truck #@$%@#& #336
It doesn't, however in this case, a the truck was going about 100mph in one direction and the car was going at 50mph in the other direction. If they are similar mass (truck with 2 people and nothing into he bed vs car with 2 people in it), that is like the truck hitting a parked car at 150mph.
It would differ from a bridge abutment in that the car has a crumple zone that will absorb some of the force and the truck going faster will mean that it has more force to contribute to the equation and it will probably push the car backwards.
Aaron Z
/ New truck #@$%@#& #337
Each vehicle adds force to the collision,,, assume similar weight and the weight (M) is 1000 (units does not matter,,)
V1 is 50
V2 is 100
F=1/2 M(Vsquared)
F1 = 1/2 1000 ( 2500 ) = 1,250,000
f2 = 1/2 1000 (10,000) = 5,000,000
Force total is = 6,250,000
The truck adds 80% of the force,, the 50MPH car adds 20% of the force,,,
The best way to increase force is to double the velocity, rather than double the weight,,,
That squaring of the velocity really ups the ante of the truck,,,
Now, how that force is dissipated,, that is a different subject,,,
A truck hitting a bridge at 150 velocity would be
F3 = 1/2 1000 (22,500) = 11,250,000
That is almost double the energy of the two vehicles colliding,,,
/ New truck #@$%@#& #338
Aaron Z
Correct.
/ New truck #@$%@#& #339
I bet that tumble weed would do thousands of dollars, front end damage on most trucks today. Probably some would be written off completely,
/ New truck #@$%@#& #340
Of course. But I bet the seatbelt locks wouldn't engage and that you'd be able to drive the truck home.
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Frontier Root Grapple (A64126)
Frontier Root...
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
John Deere 8330 (A64126)
John Deere 8330...
