10K Deck over tilt or with ramps
   / 10K Deck over tilt or with ramps #1
AllDodge
S, Central, KY
Terramite T5C, Kubota M9540HDC24, F3990, RTV1100, Cat 416C, D3B, 955L
Have to many trailers and need more then my car trailer. Going to buy a tractor (60 to 80 hp) which will be in the 6K to 8K load range. May get some other attachments, but for right now, just trying to figure issues with two different type trailers. Plan to use a 2 5/16 or pintle but like 2 5/16 better due to less wobble/noise.
The tractor will fit between a 102 inch width trailer with fenders but a tilt trailer could make things easier in one area, but may have issues in another. What issues have been found with these different types?
I do have a 10 Ton pintle hitch trailer, but it is real heavy and would need to haul using the dump truck with a large load. I want to haul using the 2500 pickup
   / 10K Deck over tilt or with ramps #2
Gooseneck deck over with the mega ramps. I've been keeping my eye out for a sale or bargain on one in the 30-34' range.
   / 10K Deck over tilt or with ramps #3
You plan to haul an 8K tractor on a 10K trailer?
Sorry guys let me try to narrow the comments before they go to far off what I'm asking
Don't want a goose neck nor need to no why a given weight trailer will or will not work for a given load. Would appreicate comments about pintle or ball hitch trailers with and with out tilt and standard or deck tilt
   / 10K Deck over tilt or with ramps #5
Where did the OP suggest he was planning to haul an 8K tractor on a 10K trailer?
   / 10K Deck over tilt or with ramps #6
tilt just because you won't ever have to worry about an implement being in the way of ramps. Ball. With heavy jack.
   / 10K Deck over tilt or with ramps #7
I'd also say re-consider the goose neck. Way easier on the vehicle pulling the load. Wish I had gotten a GN a long time ago.
   / 10K Deck over tilt or with ramps #8
Deck over tilt with the whole bed tilting. Should be at least a 14k trailer.
   / 10K Deck over tilt or with ramps #10
A decent tilt deck overs are heavy, typically over 4k lbs easy depending length. With the mentioned 6-8k load you'll either be very close to max capacity or over even when factoring in tongue weight, which you'll want to keep reasonable with a 2500.
Unless there's a legal reason to stay at 10k I would get a 14k rated trailer (or a 14k trailer derated to 10k if need be).
Also go with the 2 5/16 ball, I've hated every pintle hitch I've ever pulled with my 2500, large trucks like a decent size dump are ok with pintle but smaller trucks with larger trailers just hang around too much for my liking.
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
CATERPILLAR D6T XL CRAWLER DOZER (A51242)
CATERPILLAR D6T XL...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
