Seat switch #$#$$#$#%
/ Seat switch #$#$$#$#% #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
My seat switch is incompatible with using my new Woodland Mills WC88 chipper. When I leave the seat to use the chipper, everything shuts down. The manual says PTO and engine will *still run* if Park Brake is engaged and selector is in Neutral-- but it doesn't behave that way.
Trying to stuff a bag of cement into the cab tractor to fool the switch isn't going to work-- my back isn't compatible with that.
I checked the circuit at the seat by unplugging the connector. On the seat side, it looks like just straight continuity-- either on or off. But on the "tractor side" of the connection there is about 1V DC coming from one of the leads. I don't want jumper it and short out the electrics of my tractor.
Does anyone know if a straight jumper will work OK, or if there is some other method? It's a Grammar air ride seat.
/ Seat switch #$#$$#$#% #2
I took a piece of wire and fastened the switch lever down last year and haven't even looked at it since.
On my tractor the switch is buried inside the seat where I cannot see it. It would look like quite a project to take the air ride seat apart but I will check that again. Am hoping for a solution that doesn't require disassembling the seat if I can avoid that.
/ Seat switch #$#$$#$#% #4
Mine is out in the open, all that I had to do was flip the seat up. Like you I was leery about bypassing it as I didn't want a big repair bill a week after I got the tractor home.
/ Seat switch #$#$$#$#% #5
Not sure about how yours is wired . A safe way to do this and still have the safety switch when you are on the seat is to add a toggle switch in parallel with the safety switch then you can turn on the toggle switch when you get off the seat then turn it back off when you get back on the seat and still have your seat safety working when you are sitting on the seat. Just don't forget to turn the toggle back off. Is there just 2 wires connected to the safety switch? If you know where the electrical connection is that turns on the PTO put the switch directly to it.
Just two wires to the seat safety switch. I'm tempted to put a jumper across it but after finding some voltage on it I am not so sure.
/ Seat switch #$#$$#$#% #7
On my 4105 the seat flips forward and the entire seat-safety-switch (a plunger type) can be wiggled out. It's in two interlocking parts so that you can replace the plunger/switch if it goes bad.
All that I did was to tie-wrap (zip-tie?) a small block of wood over the plunger = I'm always in the seat. No need to jumper the circuit. (At least in my case)
And, no, I didn't put the switch back into the seat, I coiled it and the now excess wire down onto the floor & zip-tied it to something that wouldn't move and kept it from interfering with anything else. When/if I sell the tractor on, I'll just put everything back the way it was.
/ Seat switch #$#$$#$#% #8
it should have 12v to gnd on one side when not making and 12v to gnd on both sides when making. if it has a small amount on the other side when not making that would just be some type of feedback of some sort. if you jump it that would be he same as if it was being sat on amd making
/ Seat switch #$#$$#$#% #10
Give me a break - there has to be some simple method to bypass the seat switch when using the PTO and you are out of the seat. Are you telling me that MF did not realize this situation and make provisions for it.
What mine does makes no difference here but - I turn the PTO on - stand up - the buzzer goes off for ten seconds - that's the end of the show folks. Climb down and start stuffing the chipper. My seat switch is not a cut off/disable - its a warning.
My recommendation - - since what the Owners Manual says does not seem to work - call the local MF dealer.
/ Seat switch #$#$$#$#% #11
Jumping it should not hurt anything. It is simple switch unless you have some fancy seat defroster or something (just making that up). I a couple safety switches on my old JD I bypassed because they were intermittently faulting. Drove me crazy. Jumped one and duct taped the other. Good luck.
/ Seat switch #$#$$#$#% #12
Yours is also a commercial grade tractor; mine is the dumbed down homeowner's version. :D
/ Seat switch #$#$$#$#% #13
No - I will not accept your explanation there Jstpssng. ABSOLUTELY no offense intended - BUTT - if your tractor has a rear PTO - and sufficient Hp to run a chipper or tiller or brush hog - - then there should be a legitimate way to exit the tractor with the PTO still running.
Now - as an example - my JD riding lawn mower had a kill switch on the seat - at one time. But - it has no PTO anywhere and I can see the logic behind that kill switch - although its long gone.
What do the manufacturers of smaller tractors expect - somebody to sit in the seat while others stuff the chipper or whatever.
What if you have nobody to sit in the seat of your tractor while you feed the chipper.
I can envision a moment of sheer panic OR humor here. Go into my local tractor dealer - pick out a smaller tractor - also purchase a chipper - have them hook up the chipper and do a demonstration. What will they do - have a helper come out and sit on the seat - - do they have a sack of Pet Rocks to place on the seat. Does the helper come with the tractor & chipper OR do you just get the sack of Pet Rocks.
I wonder if there is some Federal law that stipulates kill switches on certain size units. Must be.
/ Seat switch #$#$$#$#% #14
Not only is the seat kill switch a pain in the azz (pun intended) when you're using the PTO, as in using a wood chipper, its also a total hindrance when one stands up while driving. Often when using the forks on my FEL, I need to stand up to see where I'm at in picking up a pallet, etc. And as soon as I raise up, the engine shuts down - PTO in use, or not.
There are also many other times when working with the bucket that I need to see exactly where the bucket is at, especially when working near a building or other fixtures. I agree that the seat kill switch has a very valuable purpose, but it is sometimes a major pain. I'm aware that on my Kubota L3400 I could simply tie that little white nylon arm down to bypass the kill switch. But so far I've simply tried to discover convenient ways to leave it functional, yet get my work done without having to go through contortions of getting off the seat while pulling the seat up with one hand and dismounting using the other.
I'm not one for bypassing safety features. However - Kubota and others need to work out a better means of providing fall-off protection. So far, all I've seen is sacrificing a pain in my azz for them covering theirs!
My owner manual describes something very similar to this. Except I get no buzzer, just engine shutdown. OK I will call the dealer on Monday. I only want to keep the engine running when the PTO is engaged-- not when the tractor is in gear. I can't find any combination where it is possible to keep the PTO running unless I am in the seat.
/ Seat switch #$#$$#$#% #16
Getting a bit off topic here... but I can stand up and slowly inch forward to manage my QA alignment or fork placement by tapping my HST pedal without killing it. I know that doesn't help the OP with his PTO problems though.
/ Seat switch #$#$$#$#% #17
PLOWHOG - ah, no - - you WANT the pro running while the tractor is in motion also. What about your brush hog or rototiller or bailer or side bar sickle mower - etc.
My bad. Yes I run an 8 foot rotary cutter using PTO when in forward gear. I meant I want to be able to leave the seat without killing PTO. I am ok with the seat switch killing the engine if I leave the seat while it is in gear. Although that is inconvenient at times it is not a deal breaker like killing the PTO to the chipper when I leave the seat.
/ Seat switch #$#$$#$#% #19
I see the use in a seat switch but it can be a pain when you stand up to look at the leading edge of your bucket or the tips of your forks. When I changed out a worn seat, I was able to jump my switch with a small piece of copper wire bent like a staple. I have never looked back.
/ Seat switch #$#$$#$#% #20
Got to have voltage on at least one side or the circuit will not know if switch is closes or open... its all about electron flow theory....
Dale
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A61165)
2017 International...
UNUSED WOLVERINE TDB-11-72W 72" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
Honda 300 Four Trax (A61166)
Honda 300 Four...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
2024 John Deere 8R 250 Tractor (A63109)
2024 John Deere 8R...
