YM 155D Snow thrower??
/ YM 155D Snow thrower?? #21
Looks EXACTLY the same as mine. Minus mine has a loader. Great looking tractor. I'm glad to see there is a few of these left that are in as good of shape as mine. I'd say you did very well on the purchase. I'd love to see a video of it running the mower.
A few things I'd suggest, run the valves on it. Mine has 370 hrs now and I went through mine when I got it and found mine were all out by .002-.005 above the spec ( I believe it is .008 ex and .006 in). Don't " " on the spec. I can check when I get home.
Id do a full service to it. Oils and filters. Hoye tractor can help you . Or a local parts store can cross the filters.
I personally would buy the "T'd" cap for the thermostart bottle. That way your return fuel will keep it full at all times. Also see if the TS works. If it heats up and doesn't start a fire, take the line and fittings apart and clean them.
I would also put the mechanical temp gauge on it. I don't like "idiot" lights. And of course check your antifreeze freeze point. I run 50/50 mix in the winter. Change it in the late spring. That's just me though.
Anyway, nice tractor. If you ever want to sell that mower let me know. Depending on where you are located I'd buy it
Thanks for all your suggestions. I planned on changing all the fluids on the machine. I have all engine oil but need a filter yet, going to order from Hoye. I have the trans oil, but was questioning the front axle oil, I was thinking 75w90 full synthetic. Mine has 370 hours on it now and was thinking about adjusting the valves on it. Was it difficult to do on yours? I am missing the radiator overflow bottle on mine, the bracket is on the radiator but that is it. So I will need to get a bottle and figure out how to mount it on the radiator. I haven't tried the fuel thermostat start on mine yet, and I haven't seen the "T'd" cap for this before. Do you have a picture of yours? I did plan on installing a mechanical thermostat in the upper radiator hose as well unless you have a better idea on this tractor? That is what I have done in my 2210d. As for the mower, I would be interested in selling it, however it looks like you are about 500 miles from me....
/ YM 155D Snow thrower?? #23
Hoye sells the T' d cap they also sell the metric adapter fitting or a whole kit. Look on their website. Choose your tractor and you see it all
/ YM 155D Snow thrower?? #24
So you are saying you won't deliver it. Hahaha.
I have all the manuals for this tractor if you need anything. Most all the P/N still come up if you search them. Alot of these engines we're in the marine industry.
Yeah I might have to hit you up for some information in your manuals at some time. Hmm 500 miles one way.... LOL. I looked on Hoye and didn't see that T'd cap. I was also wondering what other tractors wheels would fit this tractor. I am sure if I research I can found out. I am wanting another set to put turf tires on it.
/ YM 155D Snow thrower?? #26
/ YM 155D Snow thrower?? #27
Sorry this took so long, but I had a busy weekend. Here are the pictures of my recent 155d purchase. I took the mover off the tractor for now so I an do some maintenance on the little guy first. Let me know your thoughts. View attachment 576650View attachment 576651View attachment 576652View attachment 576653View attachment 576654View attachment 576654View attachment 576655
Is that mower a rebranded Bush Hog brand. Looks very similar to an old one i have that im trying to get going at some point
I don't know if it is or not Clemsonfor. It does have a genuine Yanmar tag on the side plate with a serial number. Now that doesn't mean that Brush Hog didn't make it and put a Yanmar tag on it.
/ YM 155D Snow thrower?? #29
I did plan on installing a mechanical thermostat in the upper radiator hose as well unless you have a better idea on this tractor? That is what I have done in my 2210d. ...
Thank carefully about that mechanical thermostat? That YM155 has thermosiphon cooling & hence no water pump. I wouldn't recommend a thermostat....wouldn't want to put any extra restriction in the cooling flow. Thermosiphon systems don't flow very much at the best of times and are kind of picky about their cooling.
You must keep the antifreeze to 50% ethylene glycol & 50% water, the radiator fins clean, and the gasket packing between radiator body and frame mount in good shape. The idea for the last thing is to make sure the fan is pulling air through the fins and not from past the the sides or back of the radiator.
On the block heater, I'd get that part from one of the Yanmar dealers - not from a local automotive house. Although the threads that Yanmar put in the engine block where the heater fits looks like standard US variety NPT tapered pipe thread, it is actually a slightly different thread profile used by Yanmar and threaded to the BSPT standard. Get the right one; the wrong one will thread in just almost well enough to stay in place but will leak forever, and trying to thread it in will ruin the BSPT threads in the block.
The thermostart is easy to fix or replace and lots of fun to play with. It also works pretty well for cold weather starts - although in my experience nothing works as well as a block heater and a blanket over the hood.
Nice little tractor, good luck.
rScotty
/ YM 155D Snow thrower?? #30
I thought that the ratio for thermosiphon systems for maximum flow was 30% coolant and 70% water.
/ YM 155D Snow thrower?? #31
I think that's summer. Won't you freeze up in the cold climates with 30% antifreeze? When it's 15f outside your not going t overheat unless you have a different problem so I don't think the ratio is as big a concern in winter. Other than for freeze protection.
/ YM 155D Snow thrower?? #32
Well, that will work of course....and not a bad bet if you live in the deep South. It all depends on the climate where the tractor lives. The ratio is a a balancing act depending on climate. Originally in their Service Information Bulletins circa about 1980, Yanmar gave the customer a graph and a series of numbers and and advised owners to mix for protection at the "lowest temperature anticipated".
The percentage you end up with is a sliding scale. It depends on where you live. The higher the percentage of ethylene glycol then the better the freeze protection at low temperature (up to a point)....BUT....the ethylene glycol doesn't transfer heat as well as water does, so a higher percentage of ethylene glycol means the cooling system isn't as efficient and doesn't cool as well..
BTW, there are different "coolants" today, but back when the Yanmar therosiphon system was designed the whole world used a mix of ethylene glycol and water. That was a cooling mixture that gained favor back in the 1940s and was used everywhere up until the 1990s or so. The Yanmar system is based on the assumption that the coolant you are using is pure ethylene glycol mixed with pure water. Other glycols are different.
And ethylene glycol is a weird substance itself. In pure form it freezes at a fairly high temperature....About 8 F. It is only when ethylene glycol is mixed with water that the freezing point goes way down and it becomes "antifreeze".
You can look up information on heat transfer rates of different mix percentages of water and ethylene glycol on line if curious.
Here ae SOME SPECS direct from Yanmar with my comments:
Pure water freezes (and could split the block) at 32 F. But it cools well in hot weather because it transfers heat from the engine to the radiator fins quite well.
If you replace 30% of the water with pure ethylene glycol so that you have a 30%/70% mix, that mixture won't freeze until the temperature drops below zero degress farenheit. = 0 F. Mixed like that, you've gained about 30 degrees of freeze protection and still got a mixture good for cooling during hard work in the summertime.
So if that is the climate where you live it will work for you in the winter and cool better in the summer.
40% ethylene glycol and 60% water freezes at -13 degrees F.
The MAXIMUM ethylene glycol that Yanmar recommends is 50%. A 50/50 mix of ethylene glycol and water is pretty good antifreeze. It won't freeze until the temperature gets below -36 degrees F. Since the OP lives in Nebraska, he would probably want to go with the 50/50 mix.
For Alaska or the far north, where temps are even lower those guys are going to have to run a 60/40 mixture which lowers the freezing point to -50F. But they are going to have to change it out or dilute back to a something under a 50/50 mix for the summer.
Paying attention to the ethylene glycol/water ratio is the maintenance price us old Yanmar guys pay for the simplicity of a thermosiphon system. Like a lot of the older Yanmar philosophy, it puts the work onto the owner instead of adding the complication and expense of adding another part to the tractor - in this case that would be a waterpump and thermostat.
Enjoy! rScotty - an old time Yanmar guy.
Thanks for all that great information rScotty. I guess I did not specify very well in my post. I do not plan on putting in an extra thermostat, I plan on using a temperature probe in the upper radiator hose as I did on my 2210d. See the pictures I have attached. The probe shouldn't restrict much flow if any at all, this way I have an actual gauge and keep the dummy light in place too. rScotty do you have printed information on the coolant mixture that I could refer to? I live in Nebraska and it gets hotter than **** here in the summer and colder that a witches tit in the winter so I will have to keep an eye on my ratio for sure since this is a therosiphon system. As for the block heater, I have not been able to find an actual Yanmar one, however chevy791979 did provide the JD part number for their tractors which also have the same Yanmar engine as mine would, well maybe not the exact one, but a Yanmar engine for sure. Also I did notice that Hoye also sells a block heater and I would like to think that he would have the correct threads for it, but I could be wrong. Let me know your thoughts on this. Also I am digging up information on the appropriate size 3PH snowblower for this thing. I am thinking a 50" is the biggest I would be able to go, only because that is the only size I can find around here. Temp probe.jpgTemp probe 2.JPGTemp probe 3.JPG
/ YM 155D Snow thrower?? #34
The JD part I gave you is the exact one you'll get from hoye. I got it because I work at Deere construction dealer and had it the next morning without paying shipping.
Good to hear. I actually ordered that one from Hoye today because it was the cheapest I could find that was made for that engine.
/ YM 155D Snow thrower?? #36
Thanks for all that great information rScotty. I guess I did not specify very well in my post. I do not plan on putting in an extra thermostat, I plan on using a temperature probe in the upper radiator hose as I did on my 2210d. See the pictures I have attached. The probe shouldn't restrict much flow if any at all, this way I have an actual gauge and keep the dummy light in place too. rScotty do you have printed information on the coolant mixture that I could refer to? I live in Nebraska and it gets hotter than **** here in the summer and colder that a witches tit in the winter so I will have to keep an eye on my ratio for sure since this is a therosiphon system. As for the block heater, I have not been able to find an actual Yanmar one, however chevy791979 did provide the JD part number for their tractors which also have the same Yanmar engine as mine would, well maybe not the exact one, but a Yanmar engine for sure. Also I did notice that Hoye also sells a block heater and I would like to think that he would have the correct threads for it, but I could be wrong. Let me know your thoughts on this. Also I am digging up information on the appropriate size 3PH snowblower for this thing. I am thinking a 50" is the biggest I would be able to go, only because that is the only size I can find around here.View attachment 577026
Yanmar printed a number of technical bulletins about ethylene glycol mixtures for their thermosiphon systems. They all say about the same thing, but as time went on they tried to make their mixture recommendations more "user friendly" and less technical. I've attached here a printed copy that has what I consider to be the best info.
I don't know what to expect from your radiator hose temperature probe in a thermosiphon system. Let us know how it works.
My guess - and it is just a guess - is that it would read a couple of degrees higher than a measurement made at the location of the block sensor that Yanmar used for their idiot light. Water pump systems circulate the water a lot faster than the thermosiphon so you can expect your temperature probe to show a bit differently on the YM155 from the 2210d. At least I'm assuming that the 2210d has a water pump .... I don't know the gray market Yanmars as well as I know the US models.
Thermosiphon cooling systems were originally developed for stationary engines back in an era when regulating operating temperature was something that people paid more attention to than they do today with modern pumped coolant circulation. Basically, water pumps became more popular as the hot water pump seal technology became better. Water pumps themselves used to be a high maintenance item, but no more. Thermosiphon circulation is driven by gravity instead of a pump, and never was very efficient. You'll probably even notice a difference in operating temperature between steep downhill and uphill operation. It's adequate if watched.
On my YM165 (same engine as the YM155) I replaced the on/off idiot light sensor in the block with a regular analogue temperature sender and gauge.
Here is also a photo of the analogue sensor. The sensor required an thread adapter to go from the
BTP tapered pipe threads in the Yanmar block to our NPT thread.
On the block heater, I'm sure that Hoye knows all this and will send the right block heater. Clean the threads well. Here is a picture of my block heater installation too.
Luck, rScotty
The 2210d does have a water pump and I would agree with you on the fact that the temp probe for my 155d would read higher if I would install it as described. I could just remove the dummy light sensor and put probe in like you did your YM165. Do you happen to have the thread adapter size that you used for your temp sensor?
The block heater you have installed looks exactly like the one Hoye sells and just like the one chevy791979 posted, so I assume the one I will be getting should work just fine.
I appreciate the info on the antifreeze mixture and all the info you have provided me on the Thermosiphon cooling system, that has been very helpful. :thumbsup:
Well I was able to change the front axle oil and engine oil. Installed the oil pressure gauge just like on my 2210d. Also installed that Header Tank which replaces the old Thermostart tank. I will say that I had a **** of a time removing that plug for the block heater!!! That thing was in there and had a ton of sealant on it. I had to use my torch to heat it up 6 times to get it to come out. Its in such a small area and didn't have a lot of room to move my wrench back and forth before it cooled down and wouldn't move again. Many minutes later I was able to get it out and install the block heater, which works like a champ, tried it out this morning.
It started like a champ this morning. It was 32 degrees here and it was easy starting. :thumbsup:
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
1986 VIM TACK TANKER TRAILER (A63569)
1986 VIM TACK...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59910)
1996 FRUEHAUF 45'...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Gehl RS5-19 (A62177)
