Taking Down a Tree
/ Taking Down a Tree #1
Timm250
Gold Member
Western KY
Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
Took down this Hackberry tree this weekend. Dug out around it & the pushed it over with the Case Ih Farmall 125A.
Here's a video of it going over.
Case IH 125A vs Tree - YouTube
/ Taking Down a Tree #2
Nice thanks for sharing. How do you like that tree stumper blade? Looks like a skid steer variant on a QA mount? I am thinking about one myself so I dont wear out my backhoe.
/ Taking Down a Tree #3
Nice! :thumbsup:
That's about the only thing I miss about my old IH2500b... it could drive up a tree and push it over with ease. Had to watch for the roots coming up under the tractor and limiting the front off the ground.
Like the stump bucket. This was the 1st time using it on the tractor, I normally use it on a skid steer.
The edge is sharp between the teeth & cut easily through most roots.
It's pretty heavy duty built at about 1/2" thick.
/ Taking Down a Tree #5
Sweet ! That is a serious tree. TU for sharing. I just pushed over a bunch of smaller trees (8" to 12" dia) but had to do it the old fashion way by just pushing them over with the bucket raised up 6' or so. I should have grabbed a video of that but I had no idea they would fall so fast and easy with my new beast (NH 54D Boomer). GV
/ Taking Down a Tree #6
Like it...like it a lot thanks for sharing. :thumbsup:
"Tree" Trees with one push. :dance1:
Cut the trees from the stump this afternoon and pulled it out of the way.
It was about 11' in circumference & the largest of the 3 trunks was about 23" x 28".
The smallest was 12" & the 3rd was 17" in the smallest diameter. 20181029_174603.jpeg20181029_174323.jpeg
/ Taking Down a Tree #9
So wait a minute.......you were able to yank these stumps out of the ground? Did you get rid of most of the roots first ? GV
Dug around the tree with a stump bucket, cut the roots & then pushed the tree over.
This was 3 trunks growing on one stump.
/ Taking Down a Tree #11
ok gotcha. Was this the same tree cluster as in the video?
/ Taking Down a Tree #13
Hackberry trees don't have much of a tap root. I've had several big hackberry fall over after heavy rains. I can't stand those trees.
This one had a lot of roots but no real tap root at all.
The 1st foot or so down the roots were really thick. After that they were just scattered around the root ball but ranged from 3" to 6" in diameter.
/ Taking Down a Tree #15
That works!
I'd be so leery of a branch coming down through the hood, but I guess if the tree is live and it's branches are clear of other trees the chances are less.
I'm a fan of being a tree length away from a falling tree, but that means dragging out a cable and a ladder to hook it up high so I can pull it over.
/ Taking Down a Tree #16
I've taken out thousands of trees doing something similar with my backhoe. Just dig down on all four sides to cut the roots, then push with the hoe in the direction you want it to fall. The weight of the tree keeps it in place until you push it, and the length of the tree makes sure the entire root ball comes out with the tree. It's so much faster and easier then cutting down the tree with a chainsaw and then coming back and digging out the stump!!!!
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
1999 MACK MIXER (A65643)
1999 MACK MIXER...
Mini Skid Steer (A60352)
Mini Skid Steer...
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
