Battery replacement
/ Battery replacement #1
Bluesteel
Gold Member
Illinois
LS MT 357HC
Has anyone replaced the battery on their XR yet? Curious if you went through LS or replaced with an aftermarket. The size appears to be critical due to how its mounted. Thanks.
/ Battery replacement #2
Measure your battery, and go to Wally World!
/ Battery replacement #3
yes, there are only 3 or 4 battery manufacturers, but the vast majority are made by Johnson Controls (I think that's the parent company name, or very similar) and branded differently.
I have the measurements. The tolerances are tight. The battery partially sits down in a tray and has a hold down bracket over the top. The measurements are not common such as a series 24. I have cross referenced it to a New Holland Boomer battery. We have a New Holland dealer close by. Just curious if any others had found one that fit. The battery that came in it is Rocket. NAPA couldn't cross reference it. Neither could Interstate.
Put a NAPA 7524 battery in. I wasn't sure if it would fit but ended up fitting just fine. So if anyone needs to replace their battery this one will work or can be used as a cross reference as long as the dimensions are the same.
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
CATERILLAR 299D2 SKID STEER (A64279)
CATERILLAR 299D2...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
