What size rotary cutter for M5660SUHD?
   / What size rotary cutter for M5660SUHD? #21
I too am looking for a cutter and am looking at the same criteria as Guido. I am also cutting in East TN (outside Crossville). I've been looking at the Titan 1607C as well as the Titan 1808P. I like the 1607C 3 pt in that it has a thicker deck and a thicker stump jumper than the 1808P. However, I will be cutting on some really steep slopes and an concerned about stress b/t cutter and PTO.
Lastly, I'm on a budget and I understand that quality costs and prices go way up the wider the cut. The areas I'm cutting have not been cut in at least a year, maybe 2 since last cutting. I'll be pulling behind my Kubota M7060HD12.
   / What size rotary cutter for M5660SUHD? #22
good 8' twin spindles are expensive. my advice is not to cut corners on the duty service of a brush hog like that. gearbox rated duty, deck gauge & construction, & weight are all important.
having said that, whether pull type or 3ph, your tractor is far better suited for twin spindle than the OP's 5660. given his tractor, i still maintain a heavy duty 6' hog would be better suited. best of luck shopping, show pics when you get one. assume you have loaded rear tires.... apologize, i can't help you with the name brands you mention. mine is a Rhino Turbo 96 @2000 lbs $5600 10 yrs ago
   / What size rotary cutter for M5660SUHD? #23
Picked up this 2014 barn find last month. It was only used twice. Covered in dust. I bought it for half price of new, pressure washed it off...and bam! Love it! 20180911_172837.jpeg
   / What size rotary cutter for M5660SUHD? #24
yeah boy, you got a dandy lifetime purchase
what is the lift capacity of your pull behind? don't know much about them
   / What size rotary cutter for M5660SUHD? #25
That's a nice one for sure..
That’s pretty ironic, I’m outside of Harriman!
   / What size rotary cutter for M5660SUHD? #27
Guido,
I sent you a private message that may help you in your search. We're fairly close to each other and I imagine it might help considering close proximity.
   / What size rotary cutter for M5660SUHD? #28
I think it would depend on what your mowing as well. I have a jd5400 64pto I can clip pastures with a 15ft all day long. I have a 10ft for the thick stuff. I would think an 8ft would be fine for you tractor. Bigger mean done faster too hahah
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
2016 Toro Workman GTX Utility Cart (A56857)
2016 Toro Workman...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2014 Walker Compactor (A55787)
2014 Walker...
Yanmar YT359 (A53317)
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
