OP
GuidoSarducci
Bronze Member
Does blade tip speed increase with a larger diameter single spindle mower or will 2 gearboxes give a better cut?
The twin spindles start easier because of moving less mass and normally require less horsepower.. They also bring the weight closer to the tractor so less front ballast is needed on irregular terrain as they only stick behind the tractor the same as a 42" wide bush hog. They also are twin tail wheels so they allow higher ground speed and less beating of the machine on rougher terrain..
So a twin spindle will allow you to cut wider with less horsepower, less fuel burned. The twin spindle will cover the ground faster so that is less time and fuel. So you save fuel and time. Sounds like the cheap price might be costing you more the rest of the time you own it! Yes they are about 5,000 right now for the land pride or Bush hog 7' twin spindle but in the long run they are cheaper. Seen a lot of people buy what you are and then come back for the twin!
Thanks for the detailed explanation. That’s what I was looking for, why the twin is or isn’t better than the single. I’ll be going with an 8’ twin spindle.
highly recommend ballast of some kind up front, your chassis size is small for an implement of that size/weight. with ballast, you should be fine. assume your rear tires are loaded.
& yes, agree twin spindle is the way to go (if a tractor can handle it), i will never look back @ my 5' hog days,
best of luck, stay safe
I saw a neighbor's 7' single box cut one day and I said I'd never have such. If you have any variations to your mowing area they are just too big. Better to get an 8' twin blade with dual rears. Ensure that you get the 90 hp gearbox, and not the 45 that winds up on 6' economy models most times. Standard boxes, not OEM specific self made, come int 45 and 90.
So when I went up from 6' it was with a Mohawk 8', as I described, used, originally used for highway mowing. Changed the fluid in the gearboxes, greased everything up, sharpened the blades and away I went for a great price.
Ensure you include front chains to protect your rear tires. Rear are required also in some instances like commercial mowing of roadways and such but problem with them is that they cause bunching of clippings so that your field looks lumpy rather than nice and smooth when you have finished mowing. I think if I had to have some for certain conditions I'd just put them on when needed. Not that big of a deal....3 or 4 bolts and they're off.
