Kioit vs LS vs Branson
/ Kioit vs LS vs Branson #1
Fordman98
Fort Wayne, Indiana
Kgro
So I narrowed my options to these three tractors. The kioti ck2610, the LS XG3025, and the Brason 2510h. Went and looked at all three and really like how the kioti feels but all three seem suitable and meet my needs. But as I'm just starting my search didnt get quotes for any of them. The LS dealer did say they are more than willing to throw in some attachments and make pacakge deals. So what should I be expecting to pay for these tractors with fel? Ill more than likely add 3rd function and a grapple, box blade, and a rear blade. So want to get an idea of out the door pricing that others are paying for similar purchases.
/ Kioit vs LS vs Branson #2
The ck2610 has prices all over, best price I found was at Team Tractor out of Pheonix @ $18650. Includes the upgraded 4030 loader and a few other upgrades. Best price on the LS 3025 was from Bruno's powersports out of Arkansas for $15695. Don't have any current pricing on the Branson
/ Kioit vs LS vs Branson #3
I got quoted 15700 yesterday for a xg3025h with fel. Dealer in Sc.
/ Kioit vs LS vs Branson #4
I have two Bransons; a 6640 and a 3510i. They are well built, reliable and great value for money. What makes Branson stand out over LS and Kioti is the build weight. Against competitors, Branson is just heavier on most cases. This means that you have better traction and there is less danger of tipping or roll over with a full bucket. Sounds a bit simplistic, but its true. I'm not sure of the build weight for the LS and Kioti competitors, but it is highly likely that the Branson will be heavier and therefore more stable. In the moment you need that stability you won't be thinking about what you paid. Believe me. Good Luck!
/ Kioit vs LS vs Branson #5
Just to add a bit on what broadsword6 mentioned, Branson uses little to no electronics on their tractor which is really nice since it's prone to give less problems on that side. Also most features that are usually an option on other brands, Branson just makes it standard on their tractors. Like telescopic stabilizers which are a breeze to use. Usually it comes with at least one set of remotes. It also have metal hood and fenders instead of cheap plastics all over the place.
In my country, we have the 00 series that go from 21 to 31hp, that are similar to the 2510. I've read on a local forum, people getting over 2000 hours of hard and abuse on these little machines without any kind of problem. Just regular maintenance, diesel and go get the job done.
I'd recommend going to the dealer of each brand and give a test drive for the 3 machines you are looking for. Get a feel for the tractor, controls, etc. Take a close look at build quality, since pictures doesn't really give the right justice.
/ Kioit vs LS vs Branson #6
Want a Branson deal pricing and what you get. Go to Big Tex Branson for a look, or Big Reds Branson.
/ Kioit vs LS vs Branson #7
i went with kioti - LS dealer is far away and never seen a branson dealer (pa/ohio/wv tristate area). Looked at kubota and RK (which is tym). Mahindra didn't look like it's in the same leage as the rest, very crude.
Kioti cost less than the RK with similar features added. better financing options too. And it's all steel - fenders, hood, etc. 130 hours on it since june, zero issues. Neighbor has one 20 some years old, never been repaired..it just works.
I'll have to take better look at the Bransons when the dealer is actually open. Definitely seems like a lot of happy owners. The only thing that worried me about them is future dealer and warranty support. They just seem to be a much smaller company.
I for sure plan on testing each one out before actually making a purchase. Price only means so much if you're not happy with everything about the machine.
/ Kioit vs LS vs Branson #9
I looked at Kioti, Mahindra and Branson. Sounds tedious but make a spreadsheet listing all the factors - weight, capacities, etc. Made my Branson decision clearer. Then the regen non-issue with Branson and very comfortable with my decision
/ Kioit vs LS vs Branson #10
I did a spreadsheet when shopping for my second tractor. Mine had 6 or 8 models on it before I narrowed it down after visiting dealers.
With the first tractor all I could afford and needed was a small used one, so as soon as a decent one showed up I bought it. Maybe 4 months from deciding to buy a tractor to getting one.
The second one took about six months, but I planned on doing a lot more with it and did a lot more research.
/ Kioit vs LS vs Branson #11
"They just seem to be a much smaller company." Not anymore with the TYM purchase of Branson.....so I read.
On Branson warranty service, no way could anybody beat the service I got on my 6530. I had a problem with the AC idler pulley and installation early on and the area rep. personally got involved at his option, no whining on my part, and personally got me, not only a redesigned bearing assy, but a new attachment arm and V belt (which I didn't need) to boot, in short order, no questions asked. On my cab door which I broke mowing with a rock strike (drum mower) I had a door in 3 days and the warehouse in Plainview, Tx. had 7 in stock.....my problem, not a warranty item.
/ Kioit vs LS vs Branson #12
Dealer and parts support would help make the call for me. Most are good tractors and all of them will have a bad one, once in awhile.
A local dealer that will not work with you, is not what you want. Or a distant dealer that will not support you, if you have a problem. Money is only one part of the decision. Take your time and good luck.
That's definitley good to hear! I haven't talked with my local dealer yet. Good to know the corporate company is at least very good at making their customer happy.
/ Kioit vs LS vs Branson #14
TYM bought out Branson. Ask your dealer if he thinks Branson will still be an independent brand in 10 years.
General Motors abandoned McLaughlin, Oakland, Oldsmobile, Pontiac, Hummer, Saab, Saturn, as well as Vauxhall and Opel. It's what corporations do.
Branson owners seem to like their tractors. If Branson remains a brand, they'll be fine. If they cease to exist, they will become an orphan brand.
/ Kioit vs LS vs Branson #15
I don't disagree on Branson. I think it is a good tractor and I really like it. But closest dealer was 120 miles away. With TYM buying the parent company that owns Branson, I have been told that they plan on keeping them like they are. But I think that both will merge their engineering and their plants over the next 5 years or so. This will be good for the tractor (no matter what the color) but will they continue to product the parts after the warranties are gone. I don't think that anyone can answer this. I think it is a good bet for now, if it is the tractor you think is best for you and you have a good dealer, close or not. We don't know what 10 years will do on any of the tractor brands, except maybe JD and K.
/ Kioit vs LS vs Branson #16
My first tractor was a Ford 8n - all I could afford. I'm hoping my second tractor is my last!
Talked to the branson dealer tonight. He said all of the common parts he has in stock at all times. If he doesn't the longest its taken is 5 days to get it from Branson. So that kinda reassures the parts availability part of it.
Next step I guess would be to test them all out. All three dealers have been great so far at answering any and all questions.
/ Kioit vs LS vs Branson #19
General Motors also acquired Chevrolet, in 1918.
One hundred years ago.
Corporations do that, too.
I understand that you're trying to "keep perspective" about Branson tractors, but perhaps you could use a bit for yourself, because I seem to hear this same thing from you whenever mentions them...
/ Kioit vs LS vs Branson #20
Corps merge and fold and change all the time...plymouth? sorry, gone. Mercury? Same.
Sears is well over 100 years old and won't be around long. Used to be the biggest retailer on earth...so there are no guarantees about anything.
"As goes GM, so goes the nation"...and GM went bankrupt.
PA used to have over 250 blast furnaces making steel...today there are, last I heard, 4 in the state still working.
Kodak? Polaroid?
Change is the only constant.
2003 CHEVROLET EXPRESS 3500 PASSENGER VAN (A66091)
2003 CHEVROLET...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A68183)
2006 Ford F-750...
2014 Chevrolet Sonic (A64911)
2014 Chevrolet...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2022 WEILER S450 SKIDDER (A65056)
2022 WEILER S450...
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
