Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,361
Bummer. I knew it was always going to be a solution with a limited shelf life. Way too good to be true permanently. There are alternative solutions that work similarly from other providers but they cost quite a bit more (around $100/mo). At least if/when AT&T makes the Mobley useless to me I'm free to switch to another mobile phone provider. I like to switch every few years so I can spread out my hatred evenly...
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,362
So far so good on moving my Mobley sim to a Velocity. Connection has been more stable and is even working after the storm.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,363
Rob
read the linked article,
BUT as Xfaxman said , his has not powered off since leaving it in the 30 minute setting.
Checked mine and it has also updated to the new firmware, has been on all morning with no shut downs
This is confusing because there have been times in the past where the Mobley would time out every 30 min. and did have to go into the menu and change to no time out.
Reading the power save description... has it changed??
from select on time to
(After vehicle is turned off, mobile hotspot will stay on for) which would mean the Mobley will look for a voltage drop?
If worse comes to worse may have to try what Sodamo did and use the sim in another unit, but if it will keep working all day on the 30 minute setting maybe no problem.
The Mobleys will shut down if the supply voltage drops below 11.5 volts also.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,364
I did read the article in its entirety. I'm just saying that this is an action that likely signals that AT&T will put an end to the 'typical' use of the Mobley. Whether that happens immediately with this update or is just coming soon I don't know. But it won't last forever. I predict in less than a year the Mobley will no longer be what it is today.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,365
New software version eliminates the "No Time Out" option. I had read about this on Howard Forums and had been checking to see if mine had been updated.
I turn my Mobley off every night and on when I get up in the morning. A few days ago it quit 30 minutes after I turned it on. I looked at the LEDs, power was on, Wi-Fi was off.
Powered off and back on, checked the software version, it had been updated from V1.0.1 to V1.0.3. I left it set at 30 minutes and it has never timed out again.
More info: AT&T Pushes Mobley Firmware Update VM62V1.0.3 Removes No Time Out Power Save Setting Mobile Internet Resource Center
Tie a little computer fan on it with one of the blades trimmed. The movement should keep it from shutting off.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,366
I came home the other day and both lights were out on my Mobley. Unplugged the power and powered back on and it has been fine ever since. Kinda weird. I thought it was smoked. My Version shows
VM6200V1.0.3
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,367
There's hope - AT&T now has HARMAN spark & Unlimited In Car Data for $30/month. Looks like a Mobley for $10 more.
That link didn't take me to anything that has that description. It showed me four plans, two unlimited and two limited, but neither unlimited plans was $30 and neither mentioned in-car data.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,368
Rob
That post is gone - the more I looked into it AT&T is making it illegal to use as a hotspot outside your car. And it's speed is crippled. Try looking up Results for harman spark - AT&T Search
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,369
AT&T Spark Connected Car OBD-II Device by Harman – Is It a Mobley Replacement? – Mobile Internet Resource CenterSome info about the spark.
Summary of details confirmed:
SIM card is not user accessible for removing
Wi-Fi turns off as soon as you remove device from OBD-II Port
Can not be powered from an adapter
Data apparently going through some sort of proxy server - ping times are as high as 200ms (on other AT&T devices in same location were 20-40 ms)
Wi-Fi turns off 10 minutes after vehicle's ignition shuts down
Wi-Fi turns off after being in same location for 30 minutes
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,370
Wht would anyone want one with those limitations.
40ft Shipping Container (A49461)
40ft Shipping...
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
