Todays shop time.
/ Todays shop time. #641
/ Todays shop time. #643
I picked up this Made in Canada pipe vise the other day for $30. Since it’s not a tool I use everyday I receiver mounted it to make it easy to use when needed.
/ Todays shop time. #644
/ Todays shop time. #645
/ Todays shop time. #646
I made a vertical receiver mount with a rotating base today. Should be useful for future fixtures. For now I can utilize it for a 360 degree rotating table.
The 24 inch diameter one inch table top was a result of dumpster diving.
/ Todays shop time. #648
And you already cleaned and painted it? :thumbsup: You are on top of things.
From the looks of the shelves behind, You might look into counselling about your "vise compulsion"..
Though I admit a similar affliction. with now fewer than 7 of the devices in my own shop. ;-) None on the shelf however.... ;-)
/ Todays shop time. #649
That's cool... and I was just at the recycle station today dumping glass, plastic, paper, and cardboard. Usually I have something for the metal bin which then gets my attention to spy on possible acquisitions.
Normally I pull more scrap metal out than I deposit. :D. Sometimes the huge bin is not full enough to retrieve stuff though. I am mad now that I didn't look today. :smiley_aafz:
/ Todays shop time. #650
/ Todays shop time. #651
I like that table idea. Looks high enough to not have to bend over to look closely at something. Every year it gets harder to see stuff.
/ Todays shop time. #652
I made this mobile table for the shop.
36”x 19” x 3” laminated wood top
2”x3” square tube
2”x3”x3/16 angle
4” greaseable swivel casters
2.5” receiver tube mounted vertically
36” working height to match work benches, welding and burning tables.
Total weight 145 pounds
/ Todays shop time. #653
Big Barn, very nice. You're on a tear!
Do you have special source for your steel stock?
Now if you tell me you milled that butcher block top yourself, I'll know for sure I'm not worthy. :)
/ Todays shop time. #654
36肺 19 x 3 laminated wood top
2肺3 square tube
2肺3肺3/16 angle
4 greaseable swivel casters
2.5 receiver tube mounted vertically
36 working height to match work benches, welding and burning tables.
View attachment 575440View attachment 575441View attachment 575442
Terry, I had to wait to get home to see your pics on something bigger than my phone. I like it a lot!
Did you laminate the wood top yourself?
What are the holes in the structural members for?
/ Todays shop time. #655
Thanks Threepoint.
No special source for steel stock. The supplier I frequent treats me well though.
I can’t take credit for the laminated wood top. There was an ad on Facebook for various lengths. The lady was keeping the only six footer for herself so I took the next longest piece for forty dollars.
Dragoneggs: the holes are purely cosmetic. Most my projects reflect a holier than thou attitude.
/ Todays shop time. #657
I figured as much! :drink: Boy do I need a Magdrill!
Actually the holes in the rectangular tube were done with sheet metal cutters on the drill press. (I don’t have a fancy setup for my mag drills like BuckitCase). It was easier for me to keep the holes parallel using the dp vise.
I used the iron worker for the holes in the angle iron. Easy peasy
/ Todays shop time. #658
I have that problem also, and I’m shorter than average!
/ Todays shop time. #659
Just not fair! :hissyfit: The iron worker is on my bucket list.
/ Todays shop time. #660
I love how clean and organized your shop is.. this is for big barn
2017 Ford Fusion (A64557)
2017 Ford Fusion...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
2011 International DuraStar 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2011 International...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
