mf 231 leaking oil
/ mf 231 leaking oil #1
mf231
mf 231
mf 231 leaking oil badly out of weep hole in belly of tractor....replaced rear main seal.....still leaking???anyone have anymore suggestions. My guy working on it is stumped...Thanks in advance
/ mf 231 leaking oil #2
it can only be coming from the front of the transmission or rear of the engine. Engine oil and hyd oil smell differently if that helps.
its def oil......any other poss place it could come from..my guy said the orginal and the new seal looked fine when he got it apart...its back apart now
/ mf 231 leaking oil #4
Sorry to hear this, seals can sometimes wear a slight groove into the crankshaft and not seal fully. I'm sure your mechanic checked this. Try a high mileage engine oil. It has a seal sweller additive in it. It may or may not help. How many hours are on the engine? Are you sure the pan gasket is not "sweating" oil?
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
1143 (A63745)
1143 (A63745)
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
