7" angle grinder
/ 7" angle grinder #62
7" angle grinder
I just know that I need to step up from my small stable of 4-1/2 inchers for cut offs and chamfering.
For GRINDING I prob use the 7-9” 40% of the time. 4.5” grinders the balance.
Almost all cut off discs and wire brushing is done with 4.5”.
And right angle die grinder with 3” discs for tight areas.
/ 7" angle grinder #63
I have an old 7" Matabo. It is almost impossible to get brushes for it, and if it ever dies I will probably buy their newest design. A 7" will flat out cut/grind crazy.... Not that the wheels and cutoff discs are cheap, either... but worth every penny.
/ 7" angle grinder #64
I have a Metabo 6" and I bought a new hercules HF recently in 4.5 The Hercules is not bad at all. I've burned through 4 of the 4.5" HF cheapies ($9.99 on sale). They're fine but at a point, you get tired of throwing them away to grab another. The metabo is very nice but very expensive.
/ 7" angle grinder #65
Just like fine women and nice tractors..... :)
/ 7" angle grinder #67
7" angle grinder
Above is a photo of my 7/9” Milwaukee. The four heater wire connections overheat over time and melt the plastic housings.
Apparently most manufacturers assemble like this and it isn’t a problem on smaller grinders as they won’t generate as much heat.
For a service tech to disassemble, replace the heaters to a USED unit would probably exceed more than half the cost of buying new.
I don’t know the exact age of my grinder as I purchased it used a few years ago, but it was an “old school” one. I can only assume they’re even worse now.
For replacement I chose Makita over Milwaukee only because it was on sale.
/ 7" angle grinder #68
Re: 7" angle grinder
that's a field coil, not a heater.
/ 7" angle grinder #69
7" angle grinder
Sorry for incorrect terminology. It’s the four wires going to the field coil.
/ 7" angle grinder #70
In his case, it is both.... :)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2019 Chevrolet Express Van, VIN # 1GB0GRFP7K1370206 (A61165)
2019 Chevrolet...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Adams 16T Tender Body (A61307)
Adams 16T Tender...
2014 PETERBILT 367 6X4 TRI/A  SLEEPER TRUCK TRACTOR (A59908)
2014 PETERBILT 367...
