Woodworking crosscut tools: Feedback needed
/ Woodworking crosscut tools: Feedback needed #1
rbstern
GA
LS MT225E, Yanmar 2210
I'm in the middle of outfitting my new basement workshop with power tools. The centerpiece is a cabinet saw I already own. I'm contemplating crosscutting setups, one of my most common operations. I can make a crosscut sled for my table saw for fine woodworking, but I also do a lot of 2x4 type projects (workbenches, functional homestead stuff like chicken coop, etc.), for which a crosscut sled is the wrong tool. Currently have an old B&D 10" miter saw on a mobile stand. Works fine, except for the very limited capacity (have to flip 2x6 to complete a cut). I'm thinking about replacing it with something that will give me more capacity, maybe with a laser guide, to make it easier on my aging eyes. Do like the big sliding miter saws, but they take up an enormous amount of space due to the tool depth.
So: New miter saw? Sliding miter?
What do you have? What do you like?
/ Woodworking crosscut tools: Feedback needed #2
This is a loaded question...in a production shop along the cut bench would be at least a 12" cut off saw (chop saw)...but a large sliding bevel/miter saw is essential for cutting wide crown moldings and such...!
pawn shops load up on power tools before the holidays...just sayin...!
/ Woodworking crosscut tools: Feedback needed #3
I have a 12" dewalt compound miter saw that works fine. The other thing you need is a stable workstand for it. Good shop lighting is more useful than laser lines, IMO.
/ Woodworking crosscut tools: Feedback needed #4
I have a 12” non-sliding miter saw and 12” sliding miter saw. I think the non slider is good for about a 8” cut. The slider is good for 12”. It’s expensive but Bosch makes a gliding miter saw that offers the same function as a SMS without the poles out the back.
/ Woodworking crosscut tools: Feedback needed #5
I would go with the sliding compound miter saw with foldable stand. I had a radial arm saw that I loved until good miter saws became popular.
/ Woodworking crosscut tools: Feedback needed #6
About five years ago I bought the cheapie 12" sliding miter saw from harbor freight. It was intended to just be a 'temporary' saw because my Makita 10" saw finally bit the dust. I have used and abused it, mainly for cutting framing lumber (2x4's through 2x12's). Lasted for a whole garage / shop build, house, decks, and misc. trim work. It's still working, but finally getting a few minor issues. Looking at the cost of a name brand saw, I seriously am considering getting another Harbor Freight special. Only high dollar saw I would get would be a 'Rigid'. They have a lifetime warranty. Pricey at around $400.
/ Woodworking crosscut tools: Feedback needed #7
I recall about 25 years ago an article in PoP Mech. that stated if you had to have just one saw for a shop, it should be a radial arm. An entire wall is dedicated to the set-up however as the saw is also capable of ripping as well as cc's.
/ Woodworking crosscut tools: Feedback needed #8
I bought a Bosch 10" sliding compound miter saw about 30 years ago when they first came out. Cuts perfect every time, never been out of adjustment in the whole time. I also have a Hitachi 10" non-slider, it is also extremely accurate. It is much lighter, I use it a lot when the big Bosch is more than what is required by the job.
/ Woodworking crosscut tools: Feedback needed #9
I like the looks of the Bosch 10" and 12" dual-bevel glide miter saws. They take up less room than a slider.
/ Woodworking crosscut tools: Feedback needed #11
I have the Dewalt 12in sliding compound w/laser. I really like it. Need a dust collection hood of some sort for it. Have it installed on its mating stand that can be folded up and stored or transported but I found it sits on it all the time because you still need a place to set the beast when you are not using it.
/ Woodworking crosscut tools: Feedback needed #12
Just to add to the choices, I have an evolution Rage 3 Compound mitre saw. It has a blade that cuts metal too if needed and still leaves a nice finish on timber.
The other alternative that seems to be gathering popularity these days is an MFT (Multi function table) with dog holes and a plunge track saw. Watch a couple of youtube vids to see how they work. Some people are doing away with the table saw and using a tracksaw for ripping as well as cross cutting on the MFT. Also it can be a lot more portable if needed. Most plunge cut saws do have a restricted depth of about 2" though. So have a look and see if it suits your needs.
/ Woodworking crosscut tools: Feedback needed #13
If you plan on cutting sheet goods get a Festool Track saw. I have had one for over 10 years - favorite saw in the shop.
/ Woodworking crosscut tools: Feedback needed #14
Like you I have a large Delta cabinet saw but a miter saw is a useful tool to compliment it. I have a higher end non-slider and it was a pain cutting wider boards and bought the cheapo HF sliding 10". I think it will do close to 12" and it is much more convenient. I will likely sell the other saw if the HF unit holds up. I have done my carry all and built dolly frames for my attachments using the HF saw....so no fine carpentry yet. But it seems to do a decent job. If I was younger I would bite the bullet and get the best sliding miter saw out there. I "made do" with the non slider for a long time and regretted not making the investment.
/ Woodworking crosscut tools: Feedback needed #15
An average quality 10" saw with a couple good carbide tipped narrow kerf blades (one 80 or 90 tooth kept just for high quality trim cuts) works awesome. The quality of the blades matter more than the saw.
/ Woodworking crosscut tools: Feedback needed #16
I have used a 10" delta that was almost worn when I got it, and a 10" hitachi I inherited. The delta still works but the hinge joint is getting sloppy and I no longer trust the angle. I replaced it with a 12" single bevel dewalt. It could really use a light, but they changed the model so the kit no longer fits, other than that I am very happy with it. I have the cutoff table set to the same height as the table saw, so each can help as an infeed/outfeed for the other. I still use the hitachi as an outside portable.
If you are going to leave the unit in one spot set up, I'd say go with a 12", sliding if it will fit the budget. Even a 12" miter runs out of cutting width pretty fast. For outside portable use, I think a sliding 10" would be a better fit being lighter. As long as you aren't expecting picture frame/cabinet maker accuracy, nearly any will do.
I have yet to get a track saw, but they are very tempting. Watching others use them there is a flexibility of use, improved accuracy, and reduced fussiness of using loose clamps and lumber to make fences for a regular circular saw. Grizzly has a "mini" track saw on sale until the 21st for 99.95, might get one for breaking down sheet goods?
/ Woodworking crosscut tools: Feedback needed #17
Folding panel saw was my choice.
/ Woodworking crosscut tools: Feedback needed #18
I have both types and the slider only comes back to the home shop when I'm cutting plywood into shelves. Pick a DeWalt up off Craigslist
/ Woodworking crosscut tools: Feedback needed #19
Bosch & Makita make a no clearance sliding miter saw.
[video]https://www.makita.ca/index2.php?event=tool&id=3264&catid=3[/video]
[video]https://www.boschtools.com/ca/en/boschtools-ocs/miter-saws-cm10gd-48431-p/[/video]
/ Woodworking crosscut tools: Feedback needed #20
I've got a dewalt 12" compound sliding miter saw. I use it for most things including fine furniture, cabinetry, trims & mouldings, and 2x4 "furniture". It's portable, accurate and takes up less room than my other saws. I'd recommend a sliding miter saw.
2018 INTERNATIONAL LT SERIES (A65643)
2018 INTERNATIONAL...
(3) Tires (A65640)
(3) Tires (A65640)
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 PETERBILT 579...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
