Todays shop time.
/ Todays shop time. #641
/ Todays shop time. #643
I picked up this Made in Canada pipe vise the other day for $30. Since it’s not a tool I use everyday I receiver mounted it to make it easy to use when needed.
/ Todays shop time. #644
/ Todays shop time. #645
/ Todays shop time. #646
I made a vertical receiver mount with a rotating base today. Should be useful for future fixtures. For now I can utilize it for a 360 degree rotating table.
The 24 inch diameter one inch table top was a result of dumpster diving.
/ Todays shop time. #648
And you already cleaned and painted it? :thumbsup: You are on top of things.
From the looks of the shelves behind, You might look into counselling about your "vise compulsion"..
Though I admit a similar affliction. with now fewer than 7 of the devices in my own shop. ;-) None on the shelf however.... ;-)
/ Todays shop time. #649
That's cool... and I was just at the recycle station today dumping glass, plastic, paper, and cardboard. Usually I have something for the metal bin which then gets my attention to spy on possible acquisitions.
Normally I pull more scrap metal out than I deposit. :D. Sometimes the huge bin is not full enough to retrieve stuff though. I am mad now that I didn't look today. :smiley_aafz:
/ Todays shop time. #650
/ Todays shop time. #651
I like that table idea. Looks high enough to not have to bend over to look closely at something. Every year it gets harder to see stuff.
/ Todays shop time. #652
I made this mobile table for the shop.
36”x 19” x 3” laminated wood top
2”x3” square tube
2”x3”x3/16 angle
4” greaseable swivel casters
2.5” receiver tube mounted vertically
36” working height to match work benches, welding and burning tables.
Total weight 145 pounds
/ Todays shop time. #653
Big Barn, very nice. You're on a tear!
Do you have special source for your steel stock?
Now if you tell me you milled that butcher block top yourself, I'll know for sure I'm not worthy. :)
/ Todays shop time. #654
36肺 19 x 3 laminated wood top
2肺3 square tube
2肺3肺3/16 angle
4 greaseable swivel casters
2.5 receiver tube mounted vertically
36 working height to match work benches, welding and burning tables.
View attachment 575440View attachment 575441View attachment 575442
Terry, I had to wait to get home to see your pics on something bigger than my phone. I like it a lot!
Did you laminate the wood top yourself?
What are the holes in the structural members for?
/ Todays shop time. #655
Thanks Threepoint.
No special source for steel stock. The supplier I frequent treats me well though.
I can’t take credit for the laminated wood top. There was an ad on Facebook for various lengths. The lady was keeping the only six footer for herself so I took the next longest piece for forty dollars.
Dragoneggs: the holes are purely cosmetic. Most my projects reflect a holier than thou attitude.
/ Todays shop time. #657
I figured as much! :drink: Boy do I need a Magdrill!
Actually the holes in the rectangular tube were done with sheet metal cutters on the drill press. (I don’t have a fancy setup for my mag drills like BuckitCase). It was easier for me to keep the holes parallel using the dp vise.
I used the iron worker for the holes in the angle iron. Easy peasy
/ Todays shop time. #658
I have that problem also, and I’m shorter than average!
/ Todays shop time. #659
Just not fair! :hissyfit: The iron worker is on my bucket list.
/ Todays shop time. #660
I love how clean and organized your shop is.. this is for big barn
