Box blade decisions
/ Box blade decisions #21
RandyinTN, have you considered their Dual Edge Grader? Titan 33 Series
No I haven't. What would be the advantages of this? My knowledge of anything like this is limited as I never owned a tractor before.
Thank you
/ Box blade decisions #23
It is designed for what you want to do. There have been many threads about them, commonly referred to as a LPGS (Land Plane Grading Scraper). Click this link for more info: Search Results - TractorByNet
You could also add a bolt on blade across the back to move dirt like a box blade.
/ Box blade decisions #24
Kubota L4330, a ~40 hp class tractor with +1150 lbs of LMC HD BB, railroad rail and 510 lb weight block:
530 lbs on a 45 hp tractor? Probably won't even notice it.
Are you using your ratchet rake for ballast or is that where you store it? Mine stays on the bucket about 90% of the time
/ Box blade decisions #25
Its easy to make a box blade heavier. This is why they make suit case weights. I have a 100lb one that almost always stays on my BB. I also use one on my 6ft york rake from time to time.
/ Box blade decisions #28
It's been stored there since I made that weight block 3 1/2 years ago.
/ Box blade decisions #30
Your tractor will handle the blade just fine. I used a 540# Woods 5 foot box blade with a 3300# 28HP New Holland 1720. That box blade had a floating tail gate and would load up material easily. I had to adjust the depth of the blade as I used it. The blade you are looking at has a fixed tailgate and will pull easier. I currently use a 7' Taylor Way that weighs in at around 650# with a fixed tailgate. I like it. Those scarfiers will cut hard pan just fine.
Usually a good rule of thumb is 100# per foot of blade for heavy duty. This is a general rule. The 5 foot Woods that I previously owned was heavier in the end plate material than my current Taylor Way. Typically a hinged tailgate box blade will weigh more and load more material than a fixed box blade. The Titan looks fine to me and is attractively priced. As others have pointed out you can always add some weight to it if needed.
/ Box blade decisions #31
My neighbor has been doing my driveway for me. He has a very old 2wd tractor with a old box blade that is not adjustable. A few passes and my road looks as good as new:)
Then I'd buy a BB as close to his in weight, size and design as possible. :)
How often does your neighbor need to do this?
/ Box blade decisions #33
Not to mention there close to 100yrs old and still going. That was a big tractor back then.
/ Box blade decisions #35
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
Wolverine Skid Steer Rock Rake (A64047)
Wolverine Skid...
TEREX RL4 LIGHT PLANT (A63569)
TEREX RL4 LIGHT...
