Box blade decisions
/ Box blade decisions #21
RandyinTN, have you considered their Dual Edge Grader? Titan 33 Series
No I haven't. What would be the advantages of this? My knowledge of anything like this is limited as I never owned a tractor before.
Thank you
/ Box blade decisions #23
It is designed for what you want to do. There have been many threads about them, commonly referred to as a LPGS (Land Plane Grading Scraper). Click this link for more info: Search Results - TractorByNet
You could also add a bolt on blade across the back to move dirt like a box blade.
/ Box blade decisions #24
Kubota L4330, a ~40 hp class tractor with +1150 lbs of LMC HD BB, railroad rail and 510 lb weight block:
530 lbs on a 45 hp tractor? Probably won't even notice it.
Are you using your ratchet rake for ballast or is that where you store it? Mine stays on the bucket about 90% of the time
/ Box blade decisions #25
Its easy to make a box blade heavier. This is why they make suit case weights. I have a 100lb one that almost always stays on my BB. I also use one on my 6ft york rake from time to time.
/ Box blade decisions #28
It's been stored there since I made that weight block 3 1/2 years ago.
/ Box blade decisions #30
Your tractor will handle the blade just fine. I used a 540# Woods 5 foot box blade with a 3300# 28HP New Holland 1720. That box blade had a floating tail gate and would load up material easily. I had to adjust the depth of the blade as I used it. The blade you are looking at has a fixed tailgate and will pull easier. I currently use a 7' Taylor Way that weighs in at around 650# with a fixed tailgate. I like it. Those scarfiers will cut hard pan just fine.
Usually a good rule of thumb is 100# per foot of blade for heavy duty. This is a general rule. The 5 foot Woods that I previously owned was heavier in the end plate material than my current Taylor Way. Typically a hinged tailgate box blade will weigh more and load more material than a fixed box blade. The Titan looks fine to me and is attractively priced. As others have pointed out you can always add some weight to it if needed.
/ Box blade decisions #31
My neighbor has been doing my driveway for me. He has a very old 2wd tractor with a old box blade that is not adjustable. A few passes and my road looks as good as new:)
Then I'd buy a BB as close to his in weight, size and design as possible. :)
How often does your neighbor need to do this?
/ Box blade decisions #33
Not to mention there close to 100yrs old and still going. That was a big tractor back then.
/ Box blade decisions #35
EZ Trail 3400 (A63688)
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
PULL TYPE DIRT PAN (A63291)
PULL TYPE DIRT PAN...
ATS T460 Mini Skid Steer (A64047)
ATS T460 Mini Skid...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
