Anyone regret filling your tires?
   / Anyone regret filling your tires? #41
After having had four tractors, three with the rear tires filled 75% and one small tractor with both filled and unfilled (at different times), I will always have mine filled. To me, the benefits of added stability and traction far outweigh any detriments.
   / Anyone regret filling your tires? #42
As other posters stated, primary tractor task is mowing. Unloaded tires work best for this application, again wet spring is a detriment. Also use tractor for snow removal. Was using the FEL float feature and that defeats the advantage of front wheel assist. When holding the snow pusher an inch or so above plowing surface, non-loaded tires perform adequately. The winter mounted back blade is only 400 lbs., not enough weight for true ballast.
Fact is, adding a heavy implement should provide all the needed ballast w/o loading tires. The wide R-4 tires used by compact manufactures isn't the best tractive solution. A narrower tire section width would actually provide better results but not look as cool!!
   / Anyone regret filling your tires? #43
I chose to not have tires filled. Time will tell. I did have two sets of weights per rear wheel (added).
   / Anyone regret filling your tires? #44
I regret getting R4 tires instead of R1.
   / Anyone regret filling your tires? #45
Please elaborate. My Kubota dealer called the morning of delivery and said by the way I upgraded you. I said how so? Tires he said.
I specified R4.
He delivered with R1W
I like the tires so far but being a newbie I am learning from the masters.
   / Anyone regret filling your tires? #46
I specified R4.
What is the w in R1W?
R4s dont do well in mud, or sideways on hills. R1s give much better traction. I have both, will not do R4 again inless its for lawn work.
   / Anyone regret filling your tires? #47
Read thru the post and someone probably did not see about front tire filling. It was mentioned but my questions goes along is it worth the added weight. Buddy has a JD5065E and has all 4 filled. The issue is 4x4 or not, the front tires tear up the sod and when in 4x4 they really tear up the sod with R1 tires
For other question, R4 set lower so it will lower center of gravity, but the trade off is they don't hold as well. But then again they don't tear up the sod so much either
   / Anyone regret filling your tires? #48
In for answer. I saw somewhere it is “wet” unsure though so far.
   / Anyone regret filling your tires? #50
Its a more aggressive R1 but not a rice tire;
R1W is defined as having a lug height about 20 percent deeper than an equivalent R1 tire, but this could vary from 15 percent to 35 percent depending on the tire and manufacturer. R2 is a tread type used typically with cane and rice or other crops grown in wet muck or flooded fields. Tread depth of R2 tires is approximately twice as deep as R1 tires.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2023 Deere 325G (A60462)
2023 Deere 325G...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
