Anyone regret filling your tires?
   / Anyone regret filling your tires? #51
One of the reasons i went with R4 on the L5030 is because of the hills, i figured a wider tire would be better. We then found they really slide sideways on hills. The R1 tires on our old tractors are narrow. I got R1 on my L3940, and they are as wide as the R4s were.
Dad got stuck last week, because he couldnt go up a muddy hill in 4x4, the R4 tires become slicks. Fortunately he was able to take a longer route around the hill to get back to the house.
   / Anyone regret filling your tires? #52
But no regret filling the tires.
   / Anyone regret filling your tires? #53
R type tires
   / Anyone regret filling your tires? #54
Larger / longer / wider tractors are more forgiving of not filling the rears. When I first got my DS4510HS, the tires were not filled. I used it for a while and It was much more stable than the LB1914 on any task even though the LB1914 had filled rears. But the larger tractor was substantially longer, wider and heavier.
One day I was lifting a heaped bucket of wet dirt (probably ~1,500 pounds). The tractor was pointed down hill when I raised the bucket to dump it. When the bucket got about 7 feet in the air a rear started to lift. So I lowered the bucket. Dumped it and made an appointment to get the rears filled with ~1,000 pounds of whatever the local JD dealer was using (not calcium).
One day I was digging a stump out with my filled rears and a 500 pound blade off the 3pt. I got the bucket hooked under a root. Curled the bucket to try to break the root and the entire rear of the tractor came completely off the ground. I also bent the bucket. So now I have filled rears and an additional 350 pounds of weights attached to the end of the draw bar a few inches inside of the 3pt eyes so I can leave it there all the time and not interfere with implements or even more ballast. Now when I know I'm going to go really heavy on a lift, I put an extra bucket on the back with my 3pt to SSAQ adapter and fill it with heavy stuff (like extra bags of cement that were left out and got hard). With filled tires, 350 pounds on the draw bar and 1000+ on the 3pt. the rear stays down.
Moral of the story - even if it doesn't seem that you need filled tires now, eventually you will do something to make you wish you had them. And in some cases you will want both filled rears and big ballast on the 3pt.
The only down sides are that the tractor is heavier for times when you want it light. But if you only fill the rears, filled rears still don't tend to sink as much as unfilled fronts. The front is what tends to dig in. And if you have R4 tires, they have so much contact patch that I don't ever see it being an issue. The other down side is that you won't be able to go as fast up hill in the highest gear due to the extra weight - kind of an obvious one.
   / Anyone regret filling your tires? #55
what is the skid steer style tread then I thought those were the R4's??
   / Anyone regret filling your tires? #57
To answer your question...
No...
I've never owned a tractor without loaded tires...
   / Anyone regret filling your tires? #58
Can't regret it because mine are not loaded. :laughing::drink:
   / Anyone regret filling your tires? #59
They will be loaded soon!
   / Anyone regret filling your tires? #60
I will be in the market for tires soon. I don’t do a lot of ground work, other than tilling the odd patch. Mostly just mowing in a pasture and in an orchard...and hauling bits of stuff around. Environment is pretty dry here. There’s a gravel drive in the winter that I plow with a blade. The property is on a slope, though. I don’t think I need R-1s, and everyone says R4s are terrible. I am considering turfs. Are there some that have a decent tread to them, and are they somewhat puncture prone compare to the R4s?
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2025 MACK GR64F DUMP TRUCK (A59823)
2025 MACK GR64F...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2017 Ford F-550 DurALift Bucket Truck (A60460)
2017 Ford F-550...
light tower (A56857)
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
