Foam filled tires
/ Foam filled tires #11
Exactly, It is not the safest, it will definetly scare the "Snot" out of yeh, and when you have the proper equipment and a High Volume Air compressor, there is no need to use this method.
It works though.
/ Foam filled tires #12
Ive seen people do it that way but not remove the valve core, now thats scary.
/ Foam filled tires #13
That's a new one on me! A few years ago I borrowed my buddy's JD410, dug a sewer ditch. Next AM, his dad needed it to dig a grave, funeral party coming, big rush, and of course a front flat. We had the come-along around it and cable clamps and 4# hammers, finally got it to take air. Wish I'd known about the ether, though not sure it would work with the wheel on the machine (no time to R+R). Thanks!
Jim
/ Foam filled tires #14
Jim
I am sure it would work with tire and wheel on the Equipment,
The couple of times I have used the method, the Tire/Wheel was off the equipment, because of a true flat(that needed inspection) , bad tube , or needed new(Used) tire.
/ Foam filled tires #15
kubota4life said:
i need a remedy for the front tires on my tractor. I have had the tractor for 1 month and already had two flats. The problem is that the tires break loose from the rim and a small air compressor won't air it back up. I'm looking at getting them filled with foam rubber, this makes the tires very heavy. Is there any alternatives?
I have the same tractor and ag tires but with 723 loader. I have had exactly the same problem. What I have noticed is that my air pressure in my tires goes down slowly over a week or two. When the pressure gets between 15 and 20 psi they can break loose from the bead. Mine always broke away at those pressures when I had a heaping full bucket of dirt and was turning. I have no trouble at 30 psi. I check the pressure in fronts often especially if I am doing heavy loader work. My pressure always drops slowly and I never find a leak. Maybe that is your problem too. If not get tubes.
/ Foam filled tires #16
I have a Kubota B2910 with R4's and I have the same slow pressure loss problem on the front tires - pump them up to 35 and within a week or so they down to almost nothing. The right tire seems to lose pressure a little faster than the left. I took it down to the local tire shop to have them reseat the bead on the rim after it totally lost pressure one time - they checked it for leaks and found none.
It's been this way almost since we brought it home from the dealership back in May 2004. Had I known initially that it was going to be a problem I would have had the front tires foam-filled ...... as it is now, I've worn off enough tread that I'd hate to spend the money on getting them foamed ...... probably just stick some tubes in them.
/ Foam filled tires #17
Try running a little more air pressure to keep the tire sidewall from flexing as much and breaking the bead causing the tire to go flat. Do you have a front loader on the tractor?
/ Foam filled tires #18
My local problem leading to slow leaks is rose thorns I pick up brush hogging a neighbor's field. Sometime can't even see the buggers. I used to get them in the 3-rib fronts on my Massey 135, and thought I'd avoid them with the R-1s on my newer rig. Same problem, however. I seem to have stopped the leak with a can of goo, can't even remember who made it, maybe Armor-All? Used to take a week from 30# to 3#, now stays up.
Jim
2023 Kearney (A60462)
MASSAGE CHAIR (A58214)
2018 SPORTSTER BUMPER PULL (A60736)
2018 SPORTSTER...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2007 Jeep Liberty 4x4 SUV (A59231)
2007 Jeep Liberty...
