Kioti LB 1914 Value
/ Kioti LB 1914 Value #1
Kirk-NJ
Gold Member
Went to a yard sale yesterday and the guy had a Kioti LB1914 out back. He said it's been sitting for 3 yrs. Going to need Both rear tires cause they are flat and cracked, CalC leaked out. The engine is not locked up. Has 3pt. What is the Value as is? Owner said I could throw a battery in and start it up if I want but we know how that goes, as soon as it starts the price goes up. Assuming I do thrown a battery in and it runs what would be the value then. Would be able to run, operate the 3pt and loader but not drive cause of tires. I'm an old ford tractor guy so No nothing about these tractors Thanks,Kirk
/ Kioti LB 1914 Value #2
I would start at $500. If it sets there another year it will be scrap .
/ Kioti LB 1914 Value #3
Whats a ton of scrap go for in your area?
If it had Calcuim in the tires and it sat in it, you will need new rims.
Personally I would offer $200-250 and see what happens.
/ Kioti LB 1914 Value #4
This, who knows how many mice live in that thing and how many of the wiring harnesses they have chewed on. After a new battery it may not start due to all the chewed wires. I'd be shocked if it did start. ****, mine is in my shed and it is a constant battle keeping mice out of the tractor and that is with relatively frequent use.
Thanks for your input guys. I was going to pick it up to flip it. I have way to many projects away so I think I'm going to pass on it.
/ Kioti LB 1914 Value #6
Do you still know if it is still there? I need a set of rims for mine.....
CASE 580N BACKHOE (A65053)
CASE 580N BACKHOE...
2022 CAT 289D3 Skid Steer (A62613)
2022 CAT 289D3...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
