will this work for a top link?
/ will this work for a top link? #1
prof fate
beaver pa
kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
Delavan Ag Pumps Hydraulic Cylinder 2 X 8 PML28-112ASAE
I believe the size/price are good...
I have rear remotes - so need the connectors and lines.
Anything else needed?
this one is double the price..similar size/specs. endd are 3/4 not 1" which is probably better, but I'm sure I can find a sleeve to bring 1" down to 3/4 for the cheaper cylinder.
Hydraulic Top Link-Tractor, 3 point | Agri Supply 9599
Check valve?
Double Pilot Check Valve Kit | Agristore USA | Indianapolis, IN | AGRISTORE USA
/ will this work for a top link? #2
Shure that cylinder will work fine.
But getting those clevis ends to fit and work with typical tractor and implement top link fittings is going to be a bytch!
/ will this work for a top link? #3
Your first link will not work. A top link on a 3pt setup needs to have swivel balls on each end as the second link has. A 3 pt hitch moves somewhat (limited) side to side, not just up and down.
/ will this work for a top link? #4
A suitable knuckle could be a solution to the tractor end
/ will this work for a top link? #6
Oops... Posted a link you already have.
If you google search "top link cylinder" you will come up with other options as well. I would recommend a welded one. It is not serviceable, but I feel that welded cylinders are stronger (I have no proof of this), lighter, and easier to handle.
not too concerned about servicablity, and welded seem smaller overall so that is a definite plus.
Many I find are 250 and up..plus i'll need hoses/connectors. Trying to keep this affordable.
/ will this work for a top link? #8
One issue you might encounter with a tie rod cylinder is the square plate on the base end...it may jamb up against the pin brackets ?? Also, the port is at the very end of the base...there may not be enough room for a connector and hose end fitting without interfering with the pin plates where the cylinder attaches to the tractor...!
Not sure what I may run into..new to this, got rear remotes for this specific use, on a disk and box blade for now.
I've got to measure the length..I added lower only quick attach from titan and had to get a longer top link from TSC. Also my kioti only has one mount hole for the top link. Never enough room back there anyway.
/ will this work for a top link? #10
Just beware that if anything is in a place to bind...when the 3PH is lifted all the way up with an implement (like a box blade etc.) attached it will shear off whatever is binding (like a hose fitting etc.)...
Be sure to check for clearances with the 3PH in all positions with the tallest implement attached...
Good Luck...
/ will this work for a top link? #11
Does one of your remotes have float? That is a major plus for some implements and for hooking up you can just pull/push to the desired location. The fittings are inexpensive if they're a standard tractor style. Some manufactures have special fittings :thumbdown:. Several places make custom hoses that really aren't that much more than pre-made hoses. Plus with custom hoses you can get the ends that fit properly and avoid adapters (more $$ and more leak points).
Not sure what purpose the check valve serves on these?
/ will this work for a top link? #12
The check valve prevents drift if the valve leaks.
Cutting the ends off a generic cylinder and welding on the proper ball end pivots will save you $60 or so, not counting the costs of the ball ends fittings.
For hoses I'd get adaptors from NPT (on the cylinder and quick connects) to JIC and then use hoses with female JIC fittings. Surpluscenter and discounthydraulichose will have all that. Consider a restrictor in the rod end of the cylinder to slow it's movement.
/ will this work for a top link? #13
There is a good possibility that the end caps on the tie rod cylinder are cast metal and it may be difficult to do any welding on the base end cap...
Pilot check valves will prevent the cylinder from going into float mode...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A64279)
2008 CATERPILLAR...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
