Kubota TLB cab project
/ Kubota TLB cab project #1
Jchonline
Elite Member
Red Feather Lakes, CO
Kubota L6060, KX040-4, M7060, X1100C, M62(S)
Hello Everyone,
I will be taking delivery of a M62 in the next couple of weeks and have been giving cabs some thought. I have seen a few professionally made (Curtis for example) that are great. I really value the open station of the TLB and definitely want it open most of the year. However in the winter for snow removal it would be nice to have a way to provide some protection from the wind and the cold.
My initial thoughts are to use Lexan polycarbonate (ie plexiglass type material but more durable) and use zip ties and taped foam insulation around the contact points with the ROPS/FOPS and tractor to provide a bit of cushion. I dont want to drill any holes in the tractor, and I dont want anything that is difficult to put on or remove.
The right and rear can be completely blocked, the front I would probably do a two piece so I can remove or fold the top if needed (like golf cart). The left side will be more of a challenge as I need to figure a way to create a door.
For heat I will just use a small propane space heater.
So what are everyone痴 thoughts? Has this been tried and failed before?
/ Kubota TLB cab project #2
Sounds like fun. Watch your carbon monoxide levels.
/ Kubota TLB cab project #3
Hello Everyone,
So what are everyoneç—´ thoughts? Has this been tried and failed before?
The problem with any polycarbonate windows is they end up getting scratched up when you try and clean them. If you are blowing snow you will definitely need some kind of wiper system.
I thought the M62 had a cab option?
/ Kubota TLB cab project #4
I was tempted by the TBLs, but I was upgrading primarily for a cab. Ended up with the L4060HSTC as the TBLs close to that range were only open station with the FOPS/ROPS.
/ Kubota TLB cab project #5
I have a M59 - I am having a boat cover company fabricate a Cab. He is going to use a Auto Glass Wind Shield and the rest will be high quality boat canvas and vinyl windows. i just need to come up with a heat solution. Just purchased a HLA 3000 Hydraulic snow blade for the FEL. 1 Km driveway to keep clear. I will post pictures when it is done later in October.
/ Kubota TLB cab project #7
I plan on adding vents at the top and bottom of the Lexan to let air circulate a bit.
Why not put a tee into the line coming off if the water pump and the radiator bottom hose, then run hoses to a small heater core?
Aaron Z
Aaron Z
Good idea, maybe once the warranty runs out. I will keep it in my notes.
/ Kubota TLB cab project #9
Aaron Z
There's a free port on the inlet and outlet side of the circuit you don't have to splice or Tee the lines
/ Kubota TLB cab project #11
I'll admit there are days when a having a cab on our M59 would sure be nice. But taken all together, there is only perhaps a week during the year when I would dearly like to have a cab on the M59. The rest of the time I prefer the visibility that you get with an open station. And honestly, for most of the year the either the weather is wonderful and I'd prefer not to have the cab....or the weather flat sucks, and I just have to pick my days. As I said there's really not much of the time when a cab is necessary compared to when it is a detriment. Of course that's easy to say during Indian Summer....
What a good idea about the soft cover! Be sure to post pictures.
What I never liked about most soft covers were how poorly they were made and how crude they looked. But I know that it doesn't have to be that way. Some of the marine shops are exceptional at one-off work. We had boat canvas shop build a full dodger for our sailboat and the quality and fit was excellent. It had windows of some sort of soft flexible transparent plastic that held up real well even in snow storms. I'd imagine they could make one just as nice for a tractor.
Another option would be to just to have a lexan or glass windshield made for it, and perhaps a soft side made to velcro onto the right side. That would give a lot of blowing snow protection.
Hope to see some photos,
rScotty - sailing in a snow storm
/ Kubota TLB cab project #12
With winter coming and a tattered seat anyway, I'm considering reupholstering the seat with an electric heating element just like my truck has. 12v wiring is easy, and when it's switched off you'll never know its there. That and a hot cup of coffee in the cup holder and I'll be doing pretty well!
/ Kubota TLB cab project #13
Know of a case where soft vinyl enclosure sides were made for makeshift cab, the clear plastic "windows" distort the depth perception to the degree that distance to objects is wholly distorted. Fine for boats, tractors not so much. The canopy Kubota uses a 4 post ROPS so an aftermarket cab is NOT practical.
It was mentioned that Kubota offers a cab option for M 62. It is expensive, no A/C option.
I added an AGRITAL cab to my tractor. The factory provided ports to connect the Heater work well, doubt a warranty issue would be applicable.
/ Kubota TLB cab project #14
Years ago canvas wind breakers where available for the tractors.
They had a small cabin type enclosure around the operator with side skirts along the engine.
Some had tops and some didn't but once the tractor was warmed up the engine fan moved a
considerable amount of heat back to the operator.
After I posted I searched for tractor wind breakers, they are still available for some makes and models;
Kubota | Heater Cabs | All States Ag Parts
/ Kubota TLB cab project #15
I had vinyl sides, rear and regular auto motive glass for the front,
/ Kubota TLB cab project #16
For some reason I sent a chopper picture that has nothing to do with the subject, If you look close, there is a metal panel on each side with auto glass and a large auto glass windshield within it's own frame and using existing bolts and no drilled holes. I do not have the machine any more to take exacting pictures, but this system worked exceptionally well. For heat, I bought the Curtis branded heater,, Easy to install and operate
/ Kubota TLB cab project #17
I am brining it in on Saturday Oct 13 - I imagine he will have for at least a week. I also followed a post about how to plumb in a heater on a M59 - someone here posted a very detailed account installing a Laurin Cab and Heater with pictures. Thats the route i will go once i get the cab installed. Last winter it was -45C for a couple of weeks with lots of wind and snow. At 58 years old I need to be at least out of the wind...LOL. Thanks rScotty!
/ Kubota TLB cab project #18
Wow! That is cold! It can get cold here too, but not that cold! Actually we are lucky in that it is rare here in the Colorado Rocky Mountains to have a cold snap that lasts more than a few days. Even in midwinter there tends to be a few days each week that are sunny. And at our altitude, sunshine warms things quickly. Our snow tends to be powdery rather than wet or heavy.
What I tend to do about plowing is just let the snow sit there while we get by with our 4WD vehicles until a sunny day when I can put on the snowmobile suit or winter gear and enjoy plowing some snow.
If we had a Great Lakes or maritime climate and needed to plow everyday I'd definitely have a cab on the M59. But with our milder winters I like the handiness of being in an open cockpit machine.
If I ever get around to it, I'll make the M59 a flip up windshield just for fun. But most of what we do here we can handle with good winter clothing.
rScotty
/ Kubota TLB cab project #19
rScotty
Cold .....sat on the seat of my L39 and it just cracked and shattered ......Had to tarp the machine and leave the block heater on for 6 hours ....by mid day had it running.
/ Kubota TLB cab project #20
I am bringing it in on Saturday Oct 13 - I imagine he will have for at least a week. I also followed a post about how to plumb in a heater on a M59 - someone here posted a very detailed account installing a Laurin Cab and Heater with pictures. Thats the route i will go once i get the cab installed. Last winter it was -45C for a couple of weeks with lots of wind and snow. At 58 years old I need to be at least out of the wind...LOL. Thanks rScotty!
The more I think about using marine canvas with clear marine double-polished scratch-resistant viny on back and sides...and a glass windshield.....well, that's sounding better and better. How's it going?
rScotty
2005 PETERBILT 379 (A67714)
2005 PETERBILT 379...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
2018 JOHN DEERE 325G SKID STEER (A65056)
2018 JOHN DEERE...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2018 International WorkStar 7500 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A66736)
2018 International...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
