Pto
   / Pto #1
Atiger
Allis-Chalmers
I have an Allis-Chalmers 1952 And was wondering on the belt PTO Can it run all the time with even with the clutch push in
   / Pto #2
It's been along time since I ran a belt on a WD Allis, and I can't recall all the steps to run it.
I do recall a lever (dog) down by the clutch pedal and when that was flipped into place the clutch was held in and I believe the belt pully stopped.
That was after the belt pully was put into the run position using the jam nut and bolt that held it in the operate or non-operating position.
When it was physically disengage by sliding it out (I believe) about an inch it wouldn't be powered.
So to answer your question I recall it stopping with the foot clutch.
   / Pto
Ok it runs my front bucket it痴 an hydraulic pump and it痴 hard to run all the lifts lol
   / Pto #4
Does your Allis have the hand clutch?
That was what gave us a kind of independent pto and hydraulic lift on the WD.
   / Pto #5
belt pulley stops with foot clutch in
   / Pto #6
Hard to give an answer, when you don't even tell the model of AC you have...
SR
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
UNUSED SDLANCH SDLE20 EXCAVATOR (A57192)
UNUSED SDLANCH...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
(INOP) KUBOTA RTV900 UTV (A57192)
(INOP) KUBOTA...
