new to me rottery cutter
/ new to me rottery cutter #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
I got this cutter for $500.No play in gears, ran quiet & smooth,may need new output seal.Looks to be will built.Anybody have info for this cutter?
/ new to me rottery cutter #2
Looks good. Does it have shear bolt on the pto shaft? Do check the gearbox oil and the blades. Of course fully grease it. I hooked up to mine today and surprised how dry the pto shaft was is reason I mentioned it.
It has shear bolt. Checked u joints this is how I brought it home.I will go over it before use.
/ new to me rottery cutter #4
Yeah...I've got the same one (5 footer)...bought it new over 12 or so years ago..."IMC" if I remember correctly is the manf....I also have a 7 footer w/twin tail wheels as well...these are well made cutters..IMC is now out of business (as well as I know), but I'm pretty sure the blades can be had at Tractor Supply or other shops..just match them up if you need some..BobG in VA PS: my 5 footer has a shear bolt next to the gear box of the cutter...
/ new to me rottery cutter #6
i have had 2 of them . Still have one and use it as my primary mower. Well built. It is a IMC,Agritech,International from somewhere near Bethel Ohio. It was sold under a couple of names. After the original guy quit making them, the employees opened an impliment company called Hawkline which was later sold to Behlen Country.
/ new to me rottery cutter #7
I have one, it’s a good rugged mower.
Any chance of getting a part# for the oil seals? Thanks!
/ new to me rottery cutter #9
I might be able to come up with the seal #. My solution has been to refill the gearbox with Cornhead grease. It is a thick liquid at operating temps and turns more solid when it cools. Unless your seal is missing or completely destroyed it will fix your problem. Most gearboxes take a couple tubes. Last time I bought it, the cost was about $10 a tube.
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
John Deere 5045E for sale
John Deere 5045E...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
