new to me rottery cutter
/ new to me rottery cutter #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
I got this cutter for $500.No play in gears, ran quiet & smooth,may need new output seal.Looks to be will built.Anybody have info for this cutter?
/ new to me rottery cutter #2
Looks good. Does it have shear bolt on the pto shaft? Do check the gearbox oil and the blades. Of course fully grease it. I hooked up to mine today and surprised how dry the pto shaft was is reason I mentioned it.
It has shear bolt. Checked u joints this is how I brought it home.I will go over it before use.
/ new to me rottery cutter #4
Yeah...I've got the same one (5 footer)...bought it new over 12 or so years ago..."IMC" if I remember correctly is the manf....I also have a 7 footer w/twin tail wheels as well...these are well made cutters..IMC is now out of business (as well as I know), but I'm pretty sure the blades can be had at Tractor Supply or other shops..just match them up if you need some..BobG in VA PS: my 5 footer has a shear bolt next to the gear box of the cutter...
/ new to me rottery cutter #6
i have had 2 of them . Still have one and use it as my primary mower. Well built. It is a IMC,Agritech,International from somewhere near Bethel Ohio. It was sold under a couple of names. After the original guy quit making them, the employees opened an impliment company called Hawkline which was later sold to Behlen Country.
/ new to me rottery cutter #7
I have one, it’s a good rugged mower.
Any chance of getting a part# for the oil seals? Thanks!
/ new to me rottery cutter #9
I might be able to come up with the seal #. My solution has been to refill the gearbox with Cornhead grease. It is a thick liquid at operating temps and turns more solid when it cools. Unless your seal is missing or completely destroyed it will fix your problem. Most gearboxes take a couple tubes. Last time I bought it, the cost was about $10 a tube.
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
1997 JCB  436B WHEEL LOADER (A63569)
1997 JCB 436B...
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
McLaughlin Boring Machine (A64047)
McLaughlin Boring...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
