new to me rottery cutter
/ new to me rottery cutter #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
I got this cutter for $500.No play in gears, ran quiet & smooth,may need new output seal.Looks to be will built.Anybody have info for this cutter?
/ new to me rottery cutter #2
Looks good. Does it have shear bolt on the pto shaft? Do check the gearbox oil and the blades. Of course fully grease it. I hooked up to mine today and surprised how dry the pto shaft was is reason I mentioned it.
It has shear bolt. Checked u joints this is how I brought it home.I will go over it before use.
/ new to me rottery cutter #4
Yeah...I've got the same one (5 footer)...bought it new over 12 or so years ago..."IMC" if I remember correctly is the manf....I also have a 7 footer w/twin tail wheels as well...these are well made cutters..IMC is now out of business (as well as I know), but I'm pretty sure the blades can be had at Tractor Supply or other shops..just match them up if you need some..BobG in VA PS: my 5 footer has a shear bolt next to the gear box of the cutter...
/ new to me rottery cutter #6
i have had 2 of them . Still have one and use it as my primary mower. Well built. It is a IMC,Agritech,International from somewhere near Bethel Ohio. It was sold under a couple of names. After the original guy quit making them, the employees opened an impliment company called Hawkline which was later sold to Behlen Country.
/ new to me rottery cutter #7
I have one, it’s a good rugged mower.
Any chance of getting a part# for the oil seals? Thanks!
/ new to me rottery cutter #9
I might be able to come up with the seal #. My solution has been to refill the gearbox with Cornhead grease. It is a thick liquid at operating temps and turns more solid when it cools. Unless your seal is missing or completely destroyed it will fix your problem. Most gearboxes take a couple tubes. Last time I bought it, the cost was about $10 a tube.
17601CFL (A59228)
17601CFL (A59228)
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2023 Boxer 700HDX Compact Skid Steer (A63116)
2023 Boxer 700HDX...
2022 LIUGONG 925E EXCAVATOR (A63569)
2022 LIUGONG 925E...
2008 Unverferth 220 Rolling Harrow (A63116)
2008 Unverferth...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
