shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,353
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
First, my objective....
I plan on using a carry all on the 3pt hitch to move firewood stacked on pallets that have been cut down to 32". That will allow me to move about 1/3 of a cord (1500 lbs) of firewood at a time.
My storage area is not flat so it would be advantageous to be able to tilt the carry all to make loading and unloading of the pallets easier and have a slight tilt to keep wood from spilling out while transporting from the outside storage area to the garage. I get a lot of snow, so the pallets will be stored on concrete blocks to keep them from freezing to the ground.
The concept....
Use a 2000 lb ATV winch to replace the top link connection. The winch would be mounted to the carry all frame with the hook attached to the top link attachment point on the tractor. Use quick disconnect fittings to power the winch from the tractor electrical system. I think the tractor battery will be able to handle the load as it will be intermittent...a few seconds at a time.
Rationale
I know a tilt cylinder is the preferred answer. My dealer will not install one on my old tractor and I am not versed on hydraulics. I could learn to do it, but even doing it myself, my cost looks like about $500-600 and install time of 3-4 hours. I have the winch and controls so I figure about $50 to install it and an hour of time. As to safety, if the cable breaks, there will be about 18" of cable played out so little chance of it harming anyone. The carry all would rotate away from the tractor so no danger to the machine.
I welcome all comments on anything I should consider. Or a better idea if there is one.
The concept....
Rationale
