Ford 445 no start
/ Ford 445 no start #1
Markhodges78
Member
Ford 445
Ok so got the power steering line on my ford 445 backhoe fixed yesterday ran the machine for about 30 minutes then out of no where it surged a few times and cut off I thought my Be out of fuel so I put 5 gallons in it then it started to rain So I ran in the house came out 45 minutes later Turn the key and after a few turns over it starts up I thought cool so I shut it down for the night Got home today fired it up. It ran for five minutes then cut off cannot get it to crank back up so started checking I致e got fuel all the way to the pump but none at the injectors any ideas what else I can check
Thanks in advance
Mark
/ Ford 445 no start #2
By chance did u change the fuel filter while u were working on it??
It sounds as if your running out of fuel.. just using up whats in the filters & then theres nothing else.??
& then it slowly fills the filter back up{next day/several hours}
How did it run before u started working on the line??
"WHEN" was the last time u changed the filters??
The MOST COMMON mistake when changing those filters is>> the TOP oring MUST go UP INSIDE the filter head.. NOT ON the filter.
If u put it ON the filter, it chokes off the fuel & u end up w/ the symptoms your describing..
/ Ford 445 no start
I just bought the machine two weeks ago and I had to make repairs to the power steering line it was running fine I did remove the filter to inspect and it is dated August 3, 2018 so it’s not old and it looks good I have plenty of fuel leaving the filter going to the injector pump but none going to the injectors and now it will not start at all Also yes the O-ring was left inside the housing when the filter was removed and replaced. Are there any bleeders on the injector pump I should be aware of
Thanks for any and all help you can give
/ Ford 445 no start #4
Yes, a bleeder by the name plate..
.double screw.. 5/16 bleeder into a 7/16 body..oosen the 5/16 & spin the engine until no air comes out & tighten.
Then loosen the lines at the injectors.. ALL OF THEM at the same time.. NOT 1 at a time & spin it till fuel comes out..
Be careful>> you don't wanna burn out the starter.. Good luck
/ Ford 445 no start
That did the trick thank you so much
/ Ford 445 no start #6
Thanks for posting the results.. you don't know what that means to us that try to help..
Happy Tractoring.. TPG
/ Ford 445 no start
Thank you people like you really mean a lot to people like me. I can tear automobiles down from one to the other I’ve rebuilt engines and transmissions but I have never touched a diesel until now
So Thank you again
Mark
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
Deere 670G (A64126)
Deere 670G (A64126)
2020 Case TV370B (A64126)
2020 Case TV370B...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
