PTO Hydraulic Pump
/ PTO Hydraulic Pump #1
jamepc
Mahindra 2655
Hello all,
I purchased a front end brush cutter that's rated for 9-16 GPM. My Mahindra puts out 9 GPM so I knew it would not be powerful as it could be. Used it today for the first time and it did do real good job, just had to go slow.
So I searched for PTO pumps and found a lot of them for sale, but I'm unsure how it hooks up. Can you bypass the factory pump only when needed? Or does it have to have it's own reservoir?
Any other info like someones build, detailed instructions or even a company that makes a pre assembled unit would be great. I previously came across a 3 pt mounted self contained unit but I think it was very expensive, and I cant even find it again.
Thanks!
James
/ PTO Hydraulic Pump #3
Heres how most are set up. One good example would be a backhoe like xfaxman said.
Reservoir --> pump --> valve (quick attach for different operations possibly) -->return line to reservoir
/ PTO Hydraulic Pump #4
You need a oil tank on it. I think you could get by without a valve. Just turn off the pto when you don’t want it to run.
/ PTO Hydraulic Pump #5
You can't use just "any" valve/lines/fittings, they have to be sized for the flow of the pump or all you will be doing is making a lot of heat, AND you need a big enough oil tank to get rid of the heat you will be making because of friction.
SR
I like the idea of just turning the PTO off and on when needed, keeps it simple. But what if the brush cutter bogs down or stops completely on thick brush? Could that cause a hose to blow if there's no pressure relief bypass valve? I could keep my hand on the PTO.
Is Prince Hydraulics RD1800 relief valve a good option (I can't provide a link until I have 3 posts but easy enough to search :)
/ PTO Hydraulic Pump #8
Check on what psi you need to run the brush cutter. Some cutters require 3000 psi and lots of CUTS put out between 2000-2500. Nine gallons at 2000 psi is WAY different than 16 gal at 3000 psi. Put a grin on your face different.
I would make up or buy a kit with a 50 gal reservoir and cooling, mounted on the 3pt for good ballast and less chance of over heating.
As far as a kit goes I think Global Industries had one.
/ PTO Hydraulic Pump #9
50 gallon? How about 10-15?
/ PTO Hydraulic Pump #11
10-15 If you are running about 5-10 gpm. Rule of thumb for mobile hydraulics is 1.5-2 times the flow of the pump for tank size
/ PTO Hydraulic Pump #12
Typical design is 2X pump gpm with a cooler.
My PTO 20 GPM Prince pump has a 15 gallon tank and it works just fine with NO heat issues, so I'm sure 20 gallons would be plenty IF all the piping, valves and hoses are sized for a 20 gallon pump.
IF not, then there will be a lot more heat in the system to get rid of...
SR
/ PTO Hydraulic Pump #13
Motors create a whole lot more heat than running a few cylinders. Do your homework (sizing components) before you start spending $$$.
You'll end up with a great mower. :thumbsup:
/ PTO Hydraulic Pump #14
You should also have a cross over relief between lines so when you kill the PTO the mower doesn't have to stop instantly. That can over pressure the lines or cause other damage.
Just occurred to me that the cutter may already have the crossover built in to it.
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61572)
2023 John Deere...
2001 Freightliner Allegro Bus Class A Motorhome (A61574)
2001 Freightliner...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
2347 (A64281)
2347 (A64281)
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
