XJ2025H Wheel spacers
/ XJ2025H Wheel spacers #1
tomplum
Elite Member
PNW
XJ2025H
I wanted to give the little LS a bit wider stance. I bought a set of 2" spacers from an EBay seller PE-Motorwerks for 100$. They fit great. I'll need to procure longer wheel hub bolts though as the spacer is slightly thicker than the wheel where the studs / bolts slip through. 2pc | 2 inch | Skid Steer Wheel Spacers - 6Lug Bobcat Case John Deere CAT Terex | eBay
The stance of the tractor looks better and seems better to me. No rear world tipping data to share. To do this I thought it best to install longer bolts (16x50mm?) from the rear of the hub and tapered nuts to fit the spacer. The auto parts store had like 3 wheel nuts so I looked on EBay and bought a set of Land Rover nuts for not a lot of money. Welcome to the forum!
/ XJ2025H Wheel spacers #4
Did you modify both the front and rear?
The rears only.
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
Caterpillar D6H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D6H...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
