Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift
/ Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift #1
jkoptions
1979 Ford 3600
1977 Ford 3600 - Gas Engine
New to me tractor, was used by the city for snow removal. It has a hydraulic snow blade that is run off what looks to be a Ford factory remote (possibly made by tisco). The front hydraulics work great, but the 3 point is not functioning properly. It will only lift if you move the draft position up, the position control does nothing to lift it.
I thought there might be a diverter valve, but can't seem to find anything. The fluid is full and I think with the front hydraulics working great, that is probably not a pressure problem.
Any ideas of where to start, I have a video, but unable to include link until I have 3 posts.
Thanks
Posting to be able to post the youtube link
/ Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift #4
Do you think the 3 pt could have been bypassed since the tractor would never need it given its purpose. See if you can find information on normal hose routing and how the remote was installed.
/ Ford 3600 Front Blade Lifts/Works, 3 Point Won't Lift #5
Are you sure that you don't have your levers mixed up.
The inner lever could be your control and the outer lever your sensitivity.
The inner lever is supposed to be draft and the other lever is supposed to be position. The position control lever does nothing, the draft lever will move up the arms if bring it up.
2022 John Deere Z930M (A57148)
2022 John Deere...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
2007 FORD EXPLORER (A60736)
2007 FORD EXPLORER...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
