Removing Brush
/ Removing Brush #1
GravelRoads
PNW
Searching
I need to removed a lot of bitter brush. Some of this stuff is so big it requires a chainsaw. Been doing it manually and it is taking a toll on my 50+ year old self. I have a Kubota L48 but a mower is probably out of the question due to the very rocky terrain. Any suggestions on how I could use the Kubota? I'm willing to get an attachment if there is something that would work.
/ Removing Brush #2
For cleanup after the brush has been cut, I'd check out some of the grapple threads.
For cutting the brush, I'd suggest looking at a Clearing Saw / Brush Saw. It's like a weed whacker on steroids with bicycle-style handles. One of the optional cutters looks something like a circular saw blade. It's great for cutting woody brush and saplings. Other styles, such as the blade that looks like a giant 3-pointed ninja throwing star work well on grasses and non-woody brush.
/ Removing Brush #3
I use a Kubota B series with a 4’ medium duty LP cutter and it works on 1-2” saplings where I can take it, but for stuff where it won’t go I’ve used a Stihl FS110 cutter like John describes for many years. I tried the circular saw type blade but not for long. The 3-toothed brush blade cuts far faster for me and I’ve taken out a few miles of stuff with it. It’s actually unbelievable what it will go through quickly, and I’ve taken down pretty sizable stuff like 4” popple & firs with it with a bit of patience. You do want a harness.
I don’t have one but a grapple sounds like a great device to handle brush while seated. I’d get one but the spots where I’d need it these days are either manageable with my bush hog or not good for a tractor (swamps and rock bluffs).
/ Removing Brush #4
You have any pictures of what you’re trying to remove, with an L48 a racket rake on your bucket might work.
/ Removing Brush #5
I really want to try one of those brush grubbers/post pullers tractor supply sells but haven't worked up the courage to give one a shot yet, probably ideal for the size of stuff you're talking about (assume 3-4")e
/ Removing Brush #6
/ Removing Brush #7
This spring I noticed I could no longer see into my woods. A wall of green was filling in everywhere - #$#@ buckthorn.
I've been pulling buckthorn with a chain and a brush grubber, and this brush grubber. I've pulled 6" plus out.
My little L2900 has to be weighted down and some are easier than others. I'm happy with both of these - the chain grubber will pull over the top of small saplings many times. I've found a 20 foot 3/8" chain with a clevis slip hook around the small saplings won't slip over the top as often sometimes I can pull up 5 or 6 at a time. I place the chain at about 2' level for leverage.
I've also watched/read about using a wheel rim (thanks Jeff9366) to provide an "uplifting" experience for the tree rather than trying to pull it directly. I'm going to try this for the larger ones.
Bummer is you have to get off the tractor each time you pull one. Much better with a helper.
I'm waiting on delivery of my front end loader so I can get a ratchet rake to rip up the hundreds of thousands of sprouting buckthorn. What a nightmare. Until then a brush hog is helping me express my feelings for buckthorn.
/ Removing Brush #8
The Scotch pine in my old tree farm were dying out and I was being invaded by Buckthorn and Pokeweed. I had a tree service remove and chip about 1800 trees that had about 8-10 inch trunks on them, then, they ran this Hydro-ax over the ground that ground off all the stumps and buckthorn. I can now turn the area into a native grass area...with time.
/ Removing Brush #9
I was shocked at how fast buckthorn propagates. Now as I drive down the road I see it everywhere. I'd love to have a couple hundred horse machine with a hydro axe for a week or two :)
All these invasive species... have we learned our lesson yet? Eurasian water milfoil is ruining all our lakes and soon the zebra mussels will be choking out even more. :( I find it hard to believe with all the gene splicing and dna manipulation we can't somehow target these invaders.
/ Removing Brush
Great discussion, thanks!
I tried an FS560 but I can't handle it for long.
This is the stuff I need to remove.
Purshia tridentata
It is dry, woody, surprisingly flexible, and the trunks are strong. Some of mine have trunks that are thick enough that I need to use my chainsaw.
/ Removing Brush #12
bush honeysuckle is taking over my woods...russ
/ Removing Brush #13
Grapple just the trick,or lay chain or heavy rope out and lay the brush upon,loop end slip the other end thru put tight and haul away...I've done this many time and works fine.
/ Removing Brush #14
Wait until you see how invasive and unstoppable Japanese Knot-weed has become. :shocked:
There is a whole separate thread on that subject alone.
/ Removing Brush #15
It's too bad that invasive weeds can't be used for a new miracle drug, food, fuel, or fiber for clothes. Yet
/ Removing Brush
/ Removing Brush #17
/ Removing Brush #18
I just haven't had much luck with that first one. It typically just strips the bark and whatever meat it's attached to and slides right off the tree. I've been wanting to try the second one, but I've read reviews where the ring bends and it having a tendency to just slide off the brush also. Haven't felt like tossing the money to try it. My clumps are mostly sweet gum, poplar and privet hedge.
/ Removing Brush #19
Oh, you can bet whenever that happens, the government will put a stop to THAT! :mad:
/ Removing Brush #20
I have pretty good luck with my loader. Push it over by pushing on the shaft of the Honeysuckle (about 18" up) and it will usually expose the root ball on the loader side. Angle your loader under the root ball while curling the up slightly and pushing forward. Most will pop out. The ones that remain will die and you can get them later.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
METAL FUEL TANK (A63745)
METAL FUEL TANK...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
Isuzu 4 Cylinder Power Unit (A62183)
Isuzu 4 Cylinder...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
