Tilt Steering Wheel Lock?
/ Tilt Steering Wheel Lock? #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
I was looking at a used Bobcat CT450 yesterday. The place was closed, so nobody helped / bothered me. I couldn't find a lever to lock for the steering wheel. I thought since the Bobcat is pretty much a white Kioti (and there are a lot more Kioti owners than Bobcat owners) that someone here could help. Thanks.
/ Tilt Steering Wheel Lock? #2
I don't understand why you were looking for "a lever to lock for the steering wheel"?
Edit, now I understand, I read the title, you wanted to unlock the tilt steering column. :thumbsup:
Sorry I can't help with that.
/ Tilt Steering Wheel Lock? #3
Not sure about the older models but my 7320 has a lever below the steering wheel that I depress with my foot while I tilt the wheel toward me. When the steering wheel is in the position I want, I release my foot and the lever springs back into the locked position.
/ Tilt Steering Wheel Lock? #4
My Kubota is the same as woolyAcres describes.
Thank you!
I was looking for something nearer the steering wheel, like on cars. The steering wheel just flops down and is unlocked all the time. Maybe there's a spring missing.
The tractor is a little over an hour away from here, and I'll check that out when I go back.
/ Tilt Steering Wheel Lock? #6
Thank you!
Now I understand your first post. :thumbsup:
I have never seen a floppy steering wheel.
/ Tilt Steering Wheel Lock? #7
Find the foot lever/pedal, move steering wheel assembly to desired position, and hold it there and see if the pedal will function to lock it into position. If not it may need a spring or adjustment....
/ Tilt Steering Wheel Lock? #8
Typically the lever that releases the steering column has to be moved back into the locked position as it is not spring loaded. It should be located on the facing shroud by your shins.
