Bucket Hooks Hooks on the FEL bucket
   / Hooks on the FEL bucket #21
What about the KL6010 FEL?
if you look at the pics in your chain thread thats KL6010. Why are you opposed to just having the dealer weld them at time of purchase? That is by far simplest and most probably cheapest since there's a very good chance they will just do it for free.
If you really want to support Kenny he has weld hooks on his site too :)
   / Hooks on the FEL bucket #22
Can't comment on Ken's hooks, but they look good. But I absolutely agree put some type on there, any is better than none. One of the first things I did was weld a set on mine. I just bought painted (non zinc plated) hooks, welded a piece of 3/8" flat stock to the top and back of my bucket to distribute weight & welded the hooks onto that. Also added a big D ring in the center. Use them more than anything else, always moving things around. Actually loaded my disk harrows today with them to bring home from the farm and repair. Good luck
Here is a shot of my set up
When did I ever post I was opposed to the dealer welding on hooks?
Kens hooks can be purchased with the clevis loops as well as the hooks in one package.
   / Hooks on the FEL bucket #24
I welded a piece of 3/4” thick X 3” wide flat bar all the way across the top and put a hitch in the middle and use it to lift stuff as well as chain it down. The clevis can be turned around out of the way or taken off.
   / Hooks on the FEL bucket #25
Very clever. :thumbsup:
   / Hooks on the FEL bucket #26
Duplicate
   / Hooks on the FEL bucket #27
Just a couple of examples of using the bucket hooks. Picked up a neighbors wood splitter for repair and using my roof rake. Later.
   / Hooks on the FEL bucket #29
I had my dealer weld 4 hooks across the top of my bucket when I bought the tractor. Used them many times, would hate to not have them.
   / Hooks on the FEL bucket #30
just put some on mine last week. already used them several times
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2016 KENWORTH T880 TRI AXLE DUMP TRUCK (A56138)
2016 KENWORTH T880...
2017 DRAGON 150 BARREL TRAILER (A55745)
2017 DRAGON 150...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
