Bucket Hooks Hooks on the FEL bucket
   / Hooks on the FEL bucket #11
I installed two of Kens bolt on's on the flat spot directly in front of the loader arms..
   / Hooks on the FEL bucket #12
My Bucket hooks
The hook in the center of my bucket is by far the most used.
   / Hooks on the FEL bucket #13
Some of the Kioti bucket have a double-walled top, and we generally do not recommend the Bolt-On Hooks for those (see info on the FAQ page), so mounting on the rear or the side is a great option.
   / Hooks on the FEL bucket #14
Have 3 on mine very similar to DK35, works great!
Ricn
What about the KL6010 FEL?
   / Hooks on the FEL bucket #16
This is some what related to hooks on a bucket. From the pictures you can see that I have added the traditional 3 hooks to my bucket but I have also added two flat bars aligned with the pickup points of my John Deere FEL mounting. I use this setup to move my forks and grapple. The forks and grapple arrangement generally sits in my building and they are generally in the way when I need to get something else out of my building. The forks are a seldom used but are necessary and the grapple is mainly used in the spring and fall to do my fire wood. With this setup I do not need to remove my bucket to move the fork and grapple arrangement out of the way. I think a similar type of setup could be adapted to the skid steer style hook up and mounted on the bucket. Note I have the John Deere HD bucket, which has a floor under the top shelf, boomerang side stiffeners and a drilled cutter bar. I added the replaceable cutter bar, and used a pc of 2.5 X 2.5 X .25 angle to mount the .31 grab hooks and flat bar. Later.
   / Hooks on the FEL bucket #17
maybe post in Welding forum as well. get a strong weld
   / Hooks on the FEL bucket #18
I'm not sure on that model Randy, it's impossible to keep up with all the different buckets from all the different manufacturers.
   / Hooks on the FEL bucket #19
Bolt on hooks from KennyD .... I use them all the time and zero issues . Good Hardware .
   / Hooks on the FEL bucket #20
I didn't want to do any welding on my new tractor just yet so I ordered 2 of Kenny's BOH today. You never know how much you miss hooks until there not there when you need them.
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
STORAGE FEES (A56138)
2008 CATERPILLAR 924G (A55745)
2008 CATERPILLAR...
