Pick up cab clearance lights - required?
/ Pick up cab clearance lights - required? #21
I understand the comment about front/back plates and only applying to the state you're registered in, but this is not always true. In SC we do not register trailers at all. I got pulled over in Indiana on my way to Colorado and ticketed for being out of state without trailer plates. News to me. Learned the hard way that just because your state does not require something doesn't mean you're good in another jurisdiction.
I'd get the cab lights just because I like them anyway and no way I'm paying $65k for a big truck without them, but I'm a redneck like that anyway. If I were the OP and had any questions and planned to two out of state at some point, I'd probably just go ahead and get them just in case...
/ Pick up cab clearance lights - required? #22
And also around here, you can get any of the big 3 in 250/2500/350/3500 with or without the lights as an option. Most have them on the lot, but not all. I have never seen a 150/1500 with cab lights standard.
/ Pick up cab clearance lights - required? #23
Our '78 Chevy Scottsdale 10 had factory cab lights.
/ Pick up cab clearance lights - required? #24
NHTSA light requirements.
Above from:
BASIC EQUIPMENT REQUIRED ON ALL TRUCKS, BUSES & MPVs
Bruce
/ Pick up cab clearance lights - required? #25
Chevy/GMC 1500's have them from the factory around here..
/ Pick up cab clearance lights - required? #26
I would just add them to be on the safe side.They were $195 option on my 2016 Ram 2500..
/ Pick up cab clearance lights - required? #27
Standard on dually trucks, optional on SRW 3/4 & 1 ton.
Don't think you can get them FACTORY on any regular 1/2 ton now. I see people add them, good job, cut holes in your roof and ruin your truck.
I had factory cab lights on a SRW Super Duty, I liked the look. I hated dealing with them leaking......
/ Pick up cab clearance lights - required? #28
I'd like to know more about those trucks because there is no data to support that in the GM engineering data. It would be interesting to see a window sticker from one of them.
They have a longer bar marker light in the middle and two and two on the right and left sides.
/ Pick up cab clearance lights - required? #29
I knew 1 person years ago that had them on a 10+ year old truck, his leaked.
Do they all leak eventually?
/ Pick up cab clearance lights - required? #30
Mine came with my 08 2500 single wheel GMC. LED. One single side one failed under warranty. A hundred Bucks! The same one failed out of warranty! I don't like the old looking FORD ones, but a hundred bucks? I bought the wrong side one off E-Bay cheap, and cut it apart to work on the other side!
/ Pick up cab clearance lights - required? #31
$100 fix is crazy for a $65 option. If you build your own, that's what the upcharge is for the lights with pretty much all 3 trucks. $65.
/ Pick up cab clearance lights - required? #32
$100.oo fix for what should be a 79 cent bulb is the modern way!
Paying a dealer to replace the assembly could make the cost a lot higher still!
/ Pick up cab clearance lights - required? #33
I am not sure.
Mine was a 2000 and they leaked, I ended up siliconing around the bases AND the lense. No more leaks. A couple years later, I had a bulb burn out, replaced it and didn't reseal with silicon and it leaked between the orange globe and the black base until I sealed again. I actually pulled the headliner down and saw the water dripping in from the cab light.
/ Pick up cab clearance lights - required? #34
It was always said that vehicles with AC were prone to corrosion across the top of the windshield. So, I guess having holes there does not help.
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
2018 International HX620 Quint Dump (A62613)
2018 International...
Rol-Air gas powered portable air compressor, Coal Valley, IL (A65640)
Rol-Air gas...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Colombo Twin Master (A64126)
Colombo Twin...
