Mowing linked pedal question
/ linked pedal question #1
PA hayseed
The real central PA
nx5010 hst cab
This NX HST CAB is new to me, so here it goes:
It has been raining for weeks, finally getting a chance to cut a field with the new tractor. Had the rpm speed up high (after starting mower), had linked pedal on, 2 wd, and PTO on for 7' RFM (it is cool out so there is no AC on). The tractor would surge and bog down occasionally, is this normal for the linked pedal operation? Previously if I saw high heavy wet grass in front of my old DK, I would just slow the tractor speed down and cut it. I tried to slow the tractor down with the hst pedal, but sometimes it would seem to surge forward. It definitely bogged down a bunch of times.
Looking for tips or input. TIA
/ linked pedal question #2
You can't do linked pedal with PTO engaged.....well you can, but won't keep PTO RPM steady. Linked pedal just for transport, loader work.
/ linked pedal question #3
I'm guessing linked pedal is similar to the auto speed function on my Kubota Grand L. It makes the engine speed up to match the depressing of your hydro pedal. When you are mowing, you want a steady engine speed, and you control your ground speed with the hydro pedal. In thick grass or rough terrain, you may have your engine running to keep your PTO at 540rpm, but only slight pressure on the hydro pedal to go say, 2-3 mph. Hope this helps.
Will
/ linked pedal question #4
Mine sounds similar if I I used linked pedal with a bush hog. I'll lay off the hydro and the tractor will surge a little sometimes. I suspect its because the engine is trying to slow down (in response to the pedal being released) but the PTO is "pushing" it forward and the hydro winds up overrunning a bit. I can feel it, but it's not a big "surge", it's a lurch. So it might be normal what your feeling depending on how big the surge is?
Running my 6' bush hog, I usually disable the linked pedal and set the RPMs at around 2K. I don't need full power to mow effectively, the tractor is quieter and I'm sure it's less fuel to mow a bit below full PTO speed.
/ linked pedal question #5
Might be the anti-stall that's the culprit? This function is meant to cut back on auxiliary functions' performance in order to keep the engine from stalling out.
I don't like the linked pedal operation at all. I find that it causes the engine to too readily race the RPMs.
Maybe what you're wanting to do is to set cruise? Not sure if anything different. Bottom line is that if you're pushing through material that is causing your tractor to bog down, well, your tractor is going to bog down! (time to back off the speed and allow the cutter to operate at full speed)
/ linked pedal question #6
As previously stated, linked pedal is for transport or situations where you want to control engine rpm with your foot.
The regular isochronous governor is for pto work where you want the pto to run at a constant speed, eg bush hog work.
/ linked pedal question #7
PA hayseed, assuming that you already had the rpms high with the hand throttle, I'm fairly sure that having "Linked Pedal" engaged didn't cause this. The surging and stalling sounds like what happens when the tractor just bogs down, e.g., when in high gear trying to climb too steep a hill. :) To rule it out, if you haven't already tried, disengage Linked Pedal and see if you can duplicate the condition while mowing.
On my NX4510HST Cab and CK3510SE HST, increasing the rpm with the hand throttle simply overrides the Linked Pedal function if it's engaged. BTW, I disagree with comments that Linked Pedal is only for transport and loader work. It's good for transport, yes. But it is also good for ground engagement work. I use it all the time for grading with a box blade filled with wet stone, and moving heavy snow with a rear blade. By contrast, it's not good for loader work with a bucket or a grapple. Continuous high rpms are needed for the hydraulic flow used for lift/lower, roll-back/dump, open/close. So if you are operating with Linked Pedal engaged, you have to throttle up with the hand throttle anyway, each time you perform those functions. As you know, Linked Pedal increases rpm only in response to HST pedal use.
Please report back after you finish investigating.
Thank you to all that replied. I need to do some more "experiments" to get a better understanding of this function. I need to remove variables, so that I ensure I get accurate results. I may have had the anti stall on, I am not sure, as the very first thing I did when I got the tractor was start using the loader on a big ole dirt pile. I will check back in once I get some quality seat time.
The cab gets really hot. I have to make some adjustments to how I operate this tractor compared to the old one. One annoying safety feature I cannot stand is the tractor switching off when I get up off the seat. I was so used to dropping the bucket and rear attachment, put on parking brake, and jump off the tractor. I would do what I needed to do, then get going again. Adjustments to my routine. THe cab also prohibits me from just jumping on and off (last tractor was open station). THe other thing I used to do is when attaching threepoint equipment, i used to stand to the side of the tractor and bump the pedal forward or back to line things up, cant do that anymore (I know safety violation). It seems harder to line up the hookups now, as I can't just turn around and look down.. ON the bright side the AC was chilly the other day and I had to turn it down to keep warmer. I can't wait to move snow this winter in a heated cab, no more snowman in 7 layers of clothes.
/ linked pedal question #9
Again, look in to how the anti-stall works. But, as noted, one can bog down any tractor.
**Update** NX50 hst cab
SO I made sure that linked pedal was off, that anti stall was off, and that everything but the PTO was off (except for the AC this time as it was about 90 today). Cut grass for about 4 hours, and here is what I noticed:
The tractor did not bog down or slow down this time, but the grass was pretty dry. THe tractor did surge/jerk forward several times. It is like driving a stick and kind of clutching where you get that surge forward then slower. After this happened the first time I made sure that I kept my foot pretty steady on the pedal, it took awhile but it happened again. Is this normal for these new tractors? THis is an HST so it isn't like I'm riding a clutch. It was almost like it was going to catch a higher gear then didn't.
THe other odd thing I noticed is when I would back up (with pto running) to cut around something, when I pushed the forward pedal again nothing happened. SO, I pressed the rear pedal again, then the front and it would move forward then. I got into a bind where I couldn't back up any further by a tree, and the only way I could get it to go forward again was to depress the brake pedal for about a second or two then it would go forward. Is this a new feature on the HSTs? IF so I really hate it. My last tractor was super sensitive, back forward, it would just go. I became very accustomed to this movement and I don't like the way this one is working. Maybe it needs an adjustment.
Any ideas or tips? I have no way to know if this is normal or not for these NX's.
/ linked pedal question #11
[snip]
I don't know if this might be what happened, but I'll mention it. With the Kioti side-by-side HST pedals, if you happen to accidentally press on the forward and reverse pedals at the same time, even lightly, it will cause the HST to go into safe mode momentarily, and the Calibration light will come on. You have to wait for maybe three seconds before either pedal will make the tractor move again. In the meantime, if you press either pedal without waiting, safe mode will not clear. You must keep your foot off the pedals for the full three seconds. If you're not aware of this, it's easy to cause an endless cycle, as the tendency is to keep trying to nudge the tractor either forward or backward while fiddling with the range selector lever! Again, I don't know if this might have contributed to what you describe, but next time you are on the tractor, try experimenting with it.
/ linked pedal question #12
PA hayseed, I have the same tractor just no cab. One of the things that has happened to me is if I am trying to get a close cut on uneven ground sometimes the sides of the brush hog will drag on the ground which will give that feeling of surging once it stops digging into the high place in the ground. Not saying that's your issue but did want to point out that it can happen.
Cheers,
Bob
/ linked pedal question #13
Are you seeing the "CAL" (green light) illuminating on the dash? (sorry if this was already covered- I'm doing a quick on-the-fly reply)
This may explain it, some new fangled safety feature that isn't needed. Guess I'll have to talk to my dealer about getting rid of this but keeping my warranty. My last Kioti HST tractor didn't have it, and I am not dead or missing limbs, and that thing was sensitive. bump the forward or back pedal and away it went. This thing is going to be slower. How the heck do they expect someone who may be in snow or mud with boots on to operate an HST tractor?
I'm going to call him now. I'll see what he says.
Called them, they are calling the factory and will get back to me. I will update once I have the info. Thanks.
/ linked pedal question #16
I think the momentary "safe mode" feature is to protect the tractor, not us. :)
Some of the functions that were controlled mechanically on older tractors are now "fly by wire" on the more heavily computer-controlled machines. So, for example, when you switch between the forward and reverse pedals, there will be a slight delay in response. It's quite slight but noticeable if you're used to a mechanical linkage, as I was, especially doing quick loader work. On your NX, there is a knob on the panel to the right of your seat to adjust the speed of HST pedal response. But even dialed to the fastest setting, there will be a slight delay.
As for disabling the "safe mode" delay when you hit both forward and reverse simultaneously, I'm certain that's not an option. You're right, with heavy boots in the winter, it's easier to misjudge and hit both pedals at once when you're hurrying or tired. But since I became aware of that 2-1/2 yrs ago, it hasn't happened to me again.
/ linked pedal question #17
Drive-by-wire is never going to be as responsive as mechanically controlled machines. My B7800 is rabbit quick compared to my NX. But, given the larger size of the NX I've come to appreciate it being a bit slower to launch- it's really easy to stomp on the WRONG pedal and if it were quicker to respond (though it's really not that slow, if working correctly) one might really end up causing some damage.
/ linked pedal question #18
DieselBound, Hah! My oldest loader tractor is a 25 y/o B2150HST, so I know exactly what you mean by rabbit quick with your B7800! But I too appreciate the trade off of speed for the benefits of my NX and my CK. I've also come to prefer a side-by-side HST pedal setup to the treadle pedal on my two Kubotas. That's just a matter of personal preference, but for me just being able to pivot my foot on its heel takes much less leg movement. If I'm doing 3 or 4 hrs of loader work or mowing, my right leg will sometimes get so tired with the treadle that I'll actually use my hand to help lift my knee. :laughing:
/ linked pedal question #19
I have an issue with mine which could be what you are describing. Dealer contacted Kioti, they said it's a known issue, shouldn't have left factory that way, and a simple transmission computer update is the fix. Here's what mine does...and bear with me as it's difficult to describe.
I noticed the tractor "surging" while moving at times. Acts like a automatic transmission that can't seem to find a gear...imagine you're driving down the highway in your car with cruise control set at 55mph and the transmission keeps going between 4th & 5th gear. Kind of that feel and best as I can describe it. Doesn't happen often and I can go for long periods and never have it happen. Where I DO notice it is transport and bush hogging. Anytime I have the HST pedal nearly wide open, but not quite all the way. In fact at first I thought it was me doing it - hitting bumps or whatever and my foot just releasing or mashing the pedal a bit. But not me or operator error...transmission issue. Never happens wide open (meaning HST pedal pressed all the way down) or creeping (HST pedal pressed less than 1/3 down). Will notice it most often with HST pedal pressed ALMOST all the way down....say you're trying to hold it around 90% of all the way down.... will get a jerky shudder....that feels like an auto tranny car trying to find a gear.
Like I said, really only notice bush hogging since there are areas I want to slow down a bit due to rough ground or thick/tall grass.
Could that be what you're experiencing?
Sounds exactly like what is happening with the surging. I'll call the dealer again tomorrow about that one. Thank you.
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
CENTRAL PNEUMATIC 21 GALLON ELECT. AIR COMPRESSOR (A62131)
CENTRAL PNEUMATIC...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
