Landscape rake width
/ Landscape rake width #1
Mike058
Gold Member
Key Peninsula, Wa
Kioti CK3510SE
What size will cover, but not be wider than about 55" when set at an angle?
/ Landscape rake width #4
A 7 foot at 45 degrees is approximately 59 wide
/ Landscape rake width #6
More than six but less than seven ft. My eight footer rake shrinks way more than I think it should and at times won't cover the tracks on an L4300 Kubota.
/ Landscape rake width #7
This is a basic trigonometry question. In the era of the interwebz, you can ask Google this way:
cos A deg * W"
Where A is the angle and W is the rake width. Example for a 7' rake at 45 degrees.
To find rake width for a given span S at angle A,
S" / arccos A deg
Example for 55" span at 45 degrees.
To complete the problem for the third variable...
For tractor outside tire span S and rake width W, the largest angle that will cover the tracks is found by,
arccos(S/W) in degrees
For example, 6' tire span and 7' rake width
cos A deg * W"
S" / arccos A deg
Thanks for the extra info. It will come in handy.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2018 Trail King Lowboy (A63689)
2018 Trail King...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
