Landscape rake width
/ Landscape rake width #1
Mike058
Gold Member
Key Peninsula, Wa
Kioti CK3510SE
What size will cover, but not be wider than about 55" when set at an angle?
/ Landscape rake width #4
A 7 foot at 45 degrees is approximately 59 wide
/ Landscape rake width #6
More than six but less than seven ft. My eight footer rake shrinks way more than I think it should and at times won't cover the tracks on an L4300 Kubota.
/ Landscape rake width #7
This is a basic trigonometry question. In the era of the interwebz, you can ask Google this way:
cos A deg * W"
Where A is the angle and W is the rake width. Example for a 7' rake at 45 degrees.
To find rake width for a given span S at angle A,
S" / arccos A deg
Example for 55" span at 45 degrees.
To complete the problem for the third variable...
For tractor outside tire span S and rake width W, the largest angle that will cover the tracks is found by,
arccos(S/W) in degrees
For example, 6' tire span and 7' rake width
cos A deg * W"
S" / arccos A deg
Thanks for the extra info. It will come in handy.
7102 (A61567)
7102 (A61567)
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
2010 Case 580N (A60462)
2010 Case 580N...
