How to kill a maple stump?
/ How to kill a maple stump? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
At some point our property was logged leaving behind half a dozen big leaf maple stumps. They are huge. One may be 7 feet I diameter. When maples get cut they sprout new growth. They look overly bushy. Tried roundup with little success. Anyone have other suggestions?
/ How to kill a maple stump? #2
Are you talking about foliar applications? I would use the cut-stump method -- cut off the sprouts and immediately spray the cuts with undiluted glyphosate (41%) to prevent regrowth.*
Steve
* I think the label says dilution up to 25% with water or diesel is OK for the cut-stump method. Or is it 50%?
/ How to kill a maple stump? #3
I've killed some big stumps with road salt. I had some bags that hardened up and just broke it up as much as I could and spread them around the stump.
/ How to kill a maple stump? #4
Mix 41% strength Glyphosate with 25% diesel, and use a paint BRUSH to generously apply it to the freshly cut sprout stubs.
/ How to kill a maple stump? #5
Steve
The Roundup is a great idea but do not dilute with water or it won't work. I do not dilute with anything but use full strength concentrate. Cut the branch off and immediately, if not sooner, paint with glyphosate concentrate. That will do the trick and you can search for threads I've done on the process. It's easy and works. It is the only method I use and only rarely does a new sprout reappear.
That's for killing the new growth. To get rid of the old stump you can burn a lot of it with a wood fire and a leafblower to keep the embers going on the stump. I've done threads on the process.
/ How to kill a maple stump? #6
Dig it out.
Thanks all. Will try the full blown mix. These stumps are probably 4 to 7 feet wide,
/ How to kill a maple stump? #8
How long have the trees been down, or do you know?
I've taken a few Locusts down and they try to sprout for two to three years afterwards. I just keep cutting the sprouts off and they eventually give up.
/ How to kill a maple stump? #9
If you have deer and other wildlife around, they will love you for doing that. :)
/ How to kill a maple stump? #10
41% Glyphosate diluted with diesel works just fine!
75% Glyphsoate/25% diesel.
/ How to kill a maple stump? #11
Tordon RTU
/ How to kill a maple stump? #12
In addition to the cut-stump method, you could use the hack-and-squirt method. Use a hatchet to hack into the bark of the stump, then squirt the glyphosate into the cut areas.
Steve
/ How to kill a maple stump? #13
Steve
Or use a chainsaw to make cuts in the top of the stump.
/ How to kill a maple stump? #14
Fire will work but you need to focus it by taking some scrap tin and making a cylinder around the stump to contain some firewood. Once you get a good burn going with lots of hot ambers, put another piece of tin over the cylinder and let it bake.
/ How to kill a maple stump? #15
Tordon RTU
That would be the proper tool for the job.:thumbsup: On power line R/Ws we used to have 3 guys cutting, and one treating the stumps with a backpack sprayer. You only need to cover the sapwood.
/ How to kill a maple stump? #17
I drill deep holes in them, (a bunch) and put road salt into the holes, what the moose don't eat rots and in a year or so I can break them up piece by piece.
/ How to kill a maple stump? #18
Tordon TRU is pricey -- Amazon.com: tordon rtu.
2.5 gallons of 41% glyphosate is usually less that $40 at Rural King.
Steve
I pay less than $15/qt. locally & it works by just coating the outer sapwood, not the whole stump, so it doesn't take a lot per stump. Glyphosate is sold as a "grass & weed killer", not a stump killer!
/ How to kill a maple stump? #19
I use the 55 gallon drum burning method. There are many examples on Youtube. Your large, 7 foot stump may require two or three burns but it is a simple and effective process and doesn't require back breaking work or expensive chemicals.
/ How to kill a maple stump? #20
:thumbsup:
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
2009 Ford Ranger Pickup Truck (A66736)
2009 Ford Ranger...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
2023 Maybridge B7D 6ft. Chain Harrow Tractor Attachment (A66734)
2023 Maybridge B7D...
10' Sheets of Tin (A64912)
10' Sheets of Tin...
COMBO PORTAPOTTY/TRASH TRAILER (A67714)
COMBO...
