Jacking up JD 855 to add ballast
/ Jacking up JD 855 to add ballast #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Bought WW fluid and wondering how to safely jack up the rear end safely. I have a 1 1/2 ton floor jack. It would be nice to jack both wheels up at once but I am ok with doing each side separately. Any advice on jacking points and where to place axle stands would be appreciated.
/ Jacking up JD 855 to add ballast #2
Owner manual: Place jack under tractor frame or drawbar support. DO NOT place lifting device under transmission. Transmission could become damaged
/ Jacking up JD 855 to add ballast #3
Use blocking, after getting the lift from the jack.
That is what I did when adding the WW fluid and switching tires from side to side to widen their spacing.
/ Jacking up JD 855 to add ballast #5
Better yet, get a backhoe and use the stabilizers :laughing::laughing::laughing:
/ Jacking up JD 855 to add ballast #6
Honey, I have to buy a backhoe to do my tires safely
/ Jacking up JD 855 to add ballast #7
NOT if it is a JD2038R with the 270B backhoe...:rolleyes:
From the Operator's manual
IMPORTANT: Do not raise the tractor with the backhoe stabilizers. The stabilizers are not outriggers, and will not hold the tractor off the ground. Do not let backhoe bucket contact stabilizers.
OMLVU30066
