Bolt on Grapple
/ Bolt on Grapple #1
rdl
Gatineau, Quebec
Kubota L5740
After being on the market for all these years I can't believe how many people still have not seen or heard about this bolt on grapple. Both HLA and Cotech make a version of it and all you need is a hydraulic connection and at least a class 2 pallet fork. They are relatively heavy so you need 2 people to install them but they serve a hundred and one applications. You can save yourself from buying a whole new utility grapple with one of these and they can be uninstalled when not in use.
Cotech
HLA Attachments - Single Arm Log Grapple
/ Bolt on Grapple #2
I found the Cotech last year while searching for grapples and even though I really like the idea I went with a brush type grapple instead. My main reason for wanting a fork grapple was for dealing with logs for cutting fire wood. I really liked the fact that it would clamp stuff tight to the back of the fork frame. While the brush grapple I bought has come in handy for cleaning up downed trees and branches around my yard, it doesnt work as well as I hoped it would for the firewood thing, but sure works good for cleaning up brush. The reason that I didn't get the fork grapple was because I have a tall frame on my forks and I wasnt sure that it would work with that style. I thought about modifying the frame and cutting a section out of the middle so it would fit, but I really like the tall frame the way it is. I keep thinking about the cotech though.
I live on a small 2 acre peice of land and don't need all sorts of job specific attachments because with such a small property usualy once certain jobs are done, like brush clean up, it doesn't have to be done for quite some time and having a dedicated peice of equipment for such jobs isn't really feasible. So multi use attachments for me, like adding a fork grapple to pallet forks is appealing.
/ Bolt on Grapple #3
The HLA option weighs in at 195 pounds by itself, so you add that to most fork frames and you have a pretty heavy grapple. I've seen it at NFMS in Kentucky and it's pretty big too!.
/ Bolt on Grapple
I suggest asking the company for exact measurements, I know that it comes with a long bolt at the bottom to adjust the height and you should be able to use an every longer one. The video shows the installation, even though it's brief.
/ Bolt on Grapple #5
I kind of like this one by ATI if you have a pin-on bucket like I do.
gg
/ Bolt on Grapple #6
I like my Green's Machine Thumb;made it a bolt on;maybe 60#.That with a tooth-bar makes a pretty good and useful grapple.
/ Bolt on Grapple
That's true but you need to compare the weight to a full grapple which go from 500 to 800 lbs. You are right, they are a little heavy to be considered just an add on but as an alternative to buying a full brush grapple or utility grapple, they are perfect.
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
