Flail Mower Grass getting sucked through the bearings on Mott F5
/ Grass getting sucked through the bearings on Mott F5
FWIW, I read through the entire thread and did not see any mention of your having done any gearbox service on your mower. I mention this because your last pic in post #1 shows a square plug poking up toward the PTO shaft from the gearbox area.
I'd hate to see you go to all the trouble to refurb everything and accidentally forget to service the gearbox.
I'll leave it to the 'membership' to give advice on the fluid to use and the procedure(s) involved.
BTW, good pics and details of your work.
Here's an idea for a bearing cover to kick around. You can buy the magnetic metal 'dish' at most any auto parts store to hold small parts, screws, etc. Could you adapt one of those or similar preformed metal items to allow sliding it over the 'knife shaft' possibly, with a collar of some sort with a set screw or two, to hold the dish edge against the 'wall' where the bearing is housed. Maybe the dish could remain pressed against the bearing's 'wall' and just the collar could turn with the knife's shaft?
It's a 'rough' idea of how to possibly seal the bearing from grass access, which should remedy the issue.
Hi Coyote Machine, thanks for the input and the advice. I neglected to mention that I did in fact drain the gearbox fluid and replaced it with synthetic 80-90 weight on a guess? I can redo it if that is incorrect. There is a top plug and the bottom drain plug. There are also two small plugs to check the level, I am used to only one on most equipment. I did fill it to the level of the second, highest most check plug.
I see the plugs referred to as vented in the manual, but I don't see how they are vented? The top one seems like solid metal to me??
Thank you for the compliments on the pics. I still use a Windows phone and it's a bit old and uncooperative at times lol.
Hmmm, thanks for the suggestion about using a "dish" of sorts and attaching to the mower wall. I had not thought of that, I was thinking of attaching something directly to the collar. Attaching it to the wall may eliminate the heat sink concerns that Leon is having. Thanks for the idea, any and all thoughts are welcome. I am going to go take a look at the mower in a few minutes and see if I can think of a way to implement your idea. I'd really like to be able to successfully mow with this machine, I have fallen in love with it even on such a short test mowing.
Thanks again!
Sorry if I made a mess of this thread and made it hard to follow. I will be sure to reply with quote in the future.
Chris
/ Grass getting sucked through the bearings on Mott F5 #23
206 (6206) is a common bearing. The C2 is the internal clearance designation. C3 is the most common clearance that you see. A C2 has less internal clearance so it would commonly not be a tight fit on either the shaft nor the housing. I don't know why they would use a C2 in that application. Most of the bearings that a bearing house will have will either be sealed or shielded on both sides. You can take a pick or small screw driver and pop one of them out. You would probably want a shielded one in this case. It would be a good idea to try and shield that bearing somehow.
/ Grass getting sucked through the bearings on Mott F5 #24
Thanks again!
You're welcome. On the vent plug question I would surmise the top plug may be the vent plug. It might have been a replacement for an actual vent plug which got lost and then replaced with a standard plug. Most bearings and gear sets need to be bathed in gear oil, and there must be room for expansion and venting so pressure inside the gearbox can be relieved or seals will blow out and gearbox will run dry with bad outcomes.
Again I don't know anything about your particular mower specifically, so checking with those who do may be able to clear up which oil/gear lube to use and to what plug level to fill the box. How high on the box is the top plug to which you filled to?
To the bearing shroud, (seal) you're looking to devise, another possibility is a metal small size dog water dish which might have a flange at the outer edge. I mention this because it might be able to use the flange to seal the dish to the bearing wall with an epoxy or high strength, heat resistant silicone.
Then a split collar, if there is room, to keep the grasses/debris from entering the hole where the shaft passes through the dish. my thought is by removing direct access for the grass it would have a hard time getting past the dish area, and if the dish has enough room to its smallest diameter, where the split collar would attach the grass would not have the energy to pass by the collar and find its way through to the bearing without loosing momentum, and thus have no energy left to pass to or through the bearing. I'll have to view the pics again to determine the room for the dish and split collar.
Like this:https://www.homedepot.com/p/Climax-...gclsrc=aw.ds&dclid=COODvMuT-NwCFQaiewod5ckGnQ
Well, I thought that I had posted this yesterday but either I forgot to hit Send or it timed out or something. Sorry about that.
Hi Coyote Machine, (I actually saw a coyote outside my window last week, there are plenty of them around here!)
I will take a closer look at the top plug/vent plug. I think that the top plug and the bottom drain plug were identical though, I don't recall it being vented. I don't know if I have ever seen a vented steel plug, only plastic etc. So I'm not sure what to be looking for.
I will take some pics of the smaller inspection/level plugs. Off the top of my head, I would say that the lower one was at about the midway/halfway point of the gearbox, with the higher one, that I filled to, maybe about 2/3 of the way to the top of the gearbox. I only ran it for probably less than 5 minutes before the belt smoked due to the grass wrap.
That seems like a great idea regarding the water dish and split collar. The only thing is that I have such little clearance to work with that it would have to be cut down more to a "saucer" size rather than bowl size. I had not thought of a split collar. Actually, I think that if I could just add a split collar extremely close to the collar of the bearing housing, assuming that the collar had an OD quite a bit bigger than the OD of the bearing collar, that that alone may help the problem.
The issue again comes down to clearance. I don't know if that is enough shaft to clamp a collar on to. The factory weights and even the outermost knife station are very close to the edge of the rotor shaft. I think the knife station's weld actually bevels off to the end of the shaft. It may be visible in the pics. i will have to look more closely. But I think that your idea is something that would generally work to solve the problem if I am able to implement something along those lines.
Thanks again and have a great Sunday!
/ Grass getting sucked through the bearings on Mott F5 #26
Based on your pics, it appears that you could attach a piece of bar stock to the end counterweights. Since you plan to use the heavier flails, a little more offset weight on the end might not be a bad thing.
As the grass wraps around the end of thr rotor, the pressure pushes it sideways through the OD gap of the seal washer. The piece of barstock on the rotor prevents the grass from wrapping into the gap at the end of the rotor.
The bearings in your pics are shielded. I don't think that seals will survive in this application.
Thanks for your well wishes. Got all 4 hydraulic cyls pulled from the Agco and delivered to a local repair shop. Estimate is $80-$100 per cylinder to rebuild. Hope to have it back in operation in 10 days.
Hi Thibodeau,
I'm glad to hear that you're making progress on your tractor. That financial damage on the bill for the rebuilds seems reasonable, hopefully you will be up and running again soon.
I am leaning towards a solution along the lines of what you suggest, I just don't think I have the clearances to do much else. I just don't want to make the rotor unbalanced and create other problems because it ran extremely smooth.
It rained all day here. I have not had a chance to purchase the new bearings yet, hopefully tomorrow. I was going to replace the outboard bearing on the extension shaft at the upper pulley, but I did not realize it was a flange bearing mounted in a housing and sold as one unit. It's not cheap from what I can tell. I have seen bearing inserts for this bearing which are cheaper, but I don't know how hard that is to do or press in compared to a regular bearing. I have not pulled the bearing housing off yet to inspect the bearing to see if it's worn, it may be ok. I was just going to change it because I figured it was probably the same 206kl bearing as on the shaft.
It is instead a Sealmaster S-A SK509
Also, I'll attach a pic of the gearbox to show the second highest plug that I filled the level to. As well as a pic of the spring situation. Originally, the long spring was attached to the triangular brace/bracket, it was just hooked on towards the bottom. You may be able to see a notch that it made over the years on the piece of flat stock that make the triangle. The spring did not seem to provide enough force.
I added a second one, hooking it to the long bolt going through the flange bearing. All three other bolts are shorter, this on is longer and I thought maybe it was intentionally designed that way in order to hook the spring to the bolt, although I realize that is probably unlikely. But I don't see any other points to hook the spring? It seemed to be doing fine with this set up until the grass wrap/belt smoke.
Thanks again for all of the help.
/ Grass getting sucked through the bearings on Mott F5 #28
The sk509 is easily removed from the housing. The outside of the race is ground with a spherical radius. Once the shaft is removed, use a punch to drive on the outer race 90° from the notch in three housing. The bearing will roll in the housing, and will lift out from the housing at the clearance notches. The bearings on both of my JD flails attach the same way. Hard to understand at first, but once experienced it is simple. It also makes the bearing self- aligning.
/ Grass getting sucked through the bearings on Mott F5 #29
Forgot to mention you will probably need to remove the housing from the mower frame to give the bearing room to tilt on the back side. In your pic, you would place the punch at the 4 o'clock position and drive the race inward into the housing. The bearing will flip in the housing due the the spherical radius on the outside of the race. The the bearing will lift out at the clearance notches. No reason to replace the housing unless it is cracked.
Great info Thibodeau! Thank you! I have never changed the bearing insert on a flanged baearing and had no idea how that worked. Thanks for the explanation, that clears things up a lot.
I stopped by the bearing supply to get the new bearing today. The sk509 number of the flange bearing apparently didn't cross with anything that they had or had heard of. I still need to remove mine and check it, I was just going to change it if the price was reasonable for the insert. He said that they would just need the shaft diameter to match it up.
They did have the Fafnir 206KL bearings. They close at 4:30 and were actually locked up when I got there but were able to let me in. As a result of being in a rush, I forgot to ask them if they had a sealed version as Leon suggested. I just handed them my old bearing and they gave me two new 206KL bearings. I will call them tmw about the sealed version because I will probably not have time to put these on tonight anyway.
But when I left, I noticed that there is a difference in the bearings. It is slight, but it's in an area that is critical to the grass wrap issue. I will include some pics. The inner race of the new ones protruded slightly more than on the old ones. Which would in turn push the seal washer and cutter shaft that much further away from the bearing housing collar and open up the gap around the seal washer and the bearing housing collar, making it easier for grass to get inside.
I wish I had looked closer at the original bearings before I pressed them out of the housing. Is it possible that the original race protrudes less because of beating it out of the housing with a hammer? I didn't have to whack it hard or anything, 3-4 taps for each bearing.
Also, the box for this bearing say Timken 206KL, but the nomenclature on the bearing is a little different. The bearing has :
206-L WR Z17 SFA then another spot says Z17-AF TURKEY
The back of the inner race says 206KLZ17P
I realize that the Z indicates one side shielded, but wasn't sure about the rest. And it doesn't mention the C2 tolerances etc. I think I read that post wrong and/or misunderstood it anyway. I thought that the higher the number..C2 C3 etc, the tigher the clearances. But apparently the lower the number, the tighter the clearances. So a C2 is tighter clearances apparently and a C3 is looser. Possibly Mott wanted tighter clearances due to the balancing/vibration of the shaft?
Regardless, I don't know what the new one is rated at, or if it matters??
I will ask them tmw if they have a sealed version of this and also get the shaft diameter for the flange bearing.
This may be a stupid question, but....When I get it all put back together with the new knives and bearings and belt, what would happen if I tried to mow with the mower raised up off of the ground with the 3 point, with the mower in mid air? And them made lower passes over and over?
Leon, I have read other post that you mention the vacuum that needs to be created by the mower, so this may be a bad idea or not work at all. Just trying to reduce the chance of the grass wrap for this initial first mow.
Thanks again to everyone.
/ Grass getting sucked through the bearings on Mott F5 #31
You need to place the outboard side of the outer race on a reference surface and measure the height of the inboard side of the inner race to compare the 2 bearings. It appears that the inner race protrudes above the shield more, but that doesn't necessarily mean the bearing width is different. Need data.
Will do, very good point. Hopefully they will work and I will have the mower back assembled soon.
/ Grass getting sucked through the bearings on Mott F5 #33
If you have intentions of greasing that bearing, stick with the shielded one. It will allow a little grease out so you know when to stop with the grease gun. A sealed bearing will pop the seal out if you over grease, and you won't know until it's too late. The lower the "C" number, the less internal clearance. C2 would be typically used in a high speed application or where precise locating is important. The bearing you have is no doubt a C3 and will be fine.
/ Grass getting sucked through the bearings on Mott F5 #34
Hi Goatchay,
The pic of the plugs helps. I would have done the same as far as filling. If you look at where the shaft is and the lower small square plug is in relation to it, that plug likely would represent the lowest point that gear oil should drop to with use. The next plug up, the one you filled to would cover the gears and the bath/splash would also allow for expansion inside the gearcase withOUT blowing out any seals.
I was earlier suggesting the small square top plug might have been the vent plug, got lost and then was replaced with the standard square one now in place.
Or maybe your model never had a vent, just two small plugs?
For the split collar, I was thinking about clearances. If you could get a collar that was close to the overall diameter and wasn't too wide, a suitable sized thin washer sandwiched between the bearing outer race and the split collar could prevent the grass issue. This solution might depend on whether there is built in side to side play in the shaft. Since I suspect you do not plan to remove the shaft to do the bearing work, you might have to cut the thin washer and attach the pieces to the split collar, then move it into place against the bearing race.
BTW, Coyote Machine refers to my Kioti tractor, one of the best brands on Earth! :) I am of course, familiar with the other type coyotes, they are less popular with most people. :confused3:
One other suggestion re the numerous pics- consider adding a brief description to what each pic represents or what you're trying to show us- unless completely obvious.
/ Grass getting sucked through the bearings on Mott F5 #35
Hello goatchay,
You can mow in reverse with the mower on the ground and reduce the chance of wrapping the tall Bermuda grass and brush around the flail mower rotor on the first pass.
You will have to be diligent in checking for brush wrapped around the flail mower rotor until you have everything knocked down.
You will see that more brush is left unmowed if and when the brush wrapping around the rotor occurs.
NO worries we are here for you just mow in reverse for while until you can get a few wide laps around the acreage and then you can mow in half cuts much more easily to shred the brush even finer.
Sorry for the delay in responding and/or updating. I appreciate everyone's continued advice on this. I wanted to slap a quick coat of paint on the pulleys and parts that I have removed, bearing covers, etc, so I've had all of that soaking with some carburetor parts in a 5 gallon bucket of solvent.
In the meantime, I'v been trying to swap out the blades. I can see now why my Dad would always complain when he had to change the blades on the yellow Mott lol. It's is certainly tedious. And because I have so much removed and the cutter shaft is just sitting in there, I left it hooked up to the tractor vs disconnecting it and flipping it over. So I'm doing it on my back. One good thing is that the original cotter pins are very long and skinny, not much more that an big paper clip. So I can squeeze them shut and push them out with my fingers. The replacement ones are much more stout and the new clevis pins have correspondingly bigger holes.
KWentling, thanks so much for the advice. The bearing supply that I have access to only had the ones that are identical to the original ones, one side shielded and the other open. They said that they could get double shielded but not double sealed. I do prefer the ability to be able to grease them, although at this point I just want to put on whatever will survive/alleviate the grass wrap for this first mow if something else were available. As it stands now, I am just going to install these and cross my fingers, assuming that the inner race doesn't create a clearance issue with the seal washer....I haven't had a chance to mic/measure it yet.
Thanks for the reassurance that the C3 will be adequate, I appreciate the peace of mind on that matter.
Hi Goatchay,
Hi Coyote Machine,
Thanks for the confirmation about the gearbox oil level. I may have misunderstood you in regards to the vent plug. I assumed that the large top/fill plug would be the one that would be vented. The large top/fill plug and the large drain plug both just had a dimple on the bottom side, no holes or anything. Kind of like it would be magnetic but I didn't check. Maybe the top one was replaced with another magnetic one from another mower? Or maybe it's just not vented? The smaller square plugs were solid plugs also, no venting.
I have looked closer at the shaft and I there is just no clearance at all for the split collar solution unfortunately. I wish there were because it's a great idea and also the easiest to implement. And I found one online that would be the right diameter. But it doesn't look feasible.
I didn't realize that your name referred to the tractor, sorry about that! I love Kiotis and researched them a couple of years ago. I would love to have one. Only one dealer in all of Louisiana though. Although that wouldn't stop me from owning one. It's just finances. I have an old Yanmar that the flail mower came on. I'm borrowing a friend's JD 3720 for this mowing attempt.
Thanks for the suggestion also about the pics, I appreciate it. I realize that I haven't been doing it in the most informative manner. I need to educate myself on how to put them within a message instead of at the end, and also how to add a description etc.
Thanks again!
Hello goatchay,
Hi Leon! Hope you had a good weekend. Thanks a lot for the suggestion about mowing in reverse! I didn't know that doing that would alleviate the chance of wrapping the Bahia grass, I assumed it would just wrap in the other direction? I can certainly do that especially in some of the thicker areas.
I am still brainstorming about a mechanical solution. I guess the only thing that is practical and that I would have clearance for is to weld on a spur as Thibodeau suggested. But I have changed so much, in terms of the larger knives, larger cotter pins, new bearings etc that if I have a weird vibration when I start it back up, I would like to have as few variables as possible to eliminate in terms of diagnosing the vibration. So I think that I will hold off on adding anything to the shaft for the moment. Hopefully the new knives will help a lot in reducing the chance for grass wrap.
I am shooting for getting everything reassembled tmw and giving it a shot.
Do you have any opinion on mowing with the mower raised up off of the ground initially, held up by the hitch instead of resting on the roller?
Flange bearing seems fine btw so I will leave that alone for now. j
Thanks again and hope everyone is having a good weekend!
Chris
/ Grass getting sucked through the bearings on Mott F5 #39
Got my AGCO 5670 back in service today. Here are pics of the end of my JD390 rotor shaft. You can see that the end of the rotor is recessed into a collar on the end plate. The spur is simply a bolt through a tab welded to the rotor. In your case I think you could drill through the end counterweight. Since you have increased the blade mass, you will actually need a little more offset weight on the end of the rotor to compensate.
I need to run the pressure washer on the mower. I ran it through the bank of my pond on the day my tractor blew the steering cylinder. It's been parked until today. Will wash it tomorrow. I cut a few acres of 4' high johnson grass and mixed broad leaf weeds this evening. I continue to be amazed with how well this thing cuts. 20180825_184128.jpeg20180825_184120.jpeg20180825_184030.jpeg
/ Grass getting sucked through the bearings on Mott F5 #40
I need to run the pressure washer on the mower. I ran it through the bank of my pond on the day my tractor blew the steering cylinder. It's been parked until today. Will wash it tomorrow. I cut a few acres of 4' high Johnson grass and mixed broad leaf weeds this evening. I continue to be amazed with how well this thing cuts. View attachment 568403View attachment 568404View attachment 568406
I am so glad it is working well for you. you have a mower that will work for years with no issues and if and when you need to to change the bearings the bolts used to clear any wrapped material will come out easily for you after you clean the threads of the bolt.
Do not forget to drain the gearbox if you plan on putting the mower on its back to wash it. Wear a rain coat or poncho as your going to need it due to the water blowing back at you. If you have a full face shield that will help you while washing it. I do not know how much the full face shields that have a compression band to the fit the wearer cost now.
Happy mowing.
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
2016 GMC Sierra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Sierra...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2023 Case TV380 (A62177)
2023 Case TV380...
