T654 emissions system
/ T654 emissions system #1
cdb2
Central Texas and Central Virginia
RK55HC
The T654 is one of the tractors I am considering for a new purchase, and I found an advertisement claiming it had no regen cycles. I've tried searching but have not been able to find info on the emissions/DPF system they use on this or the T754. Does anyone here know if they have regen cycles and computer control like most of the new tractors, or if they have a passive DPF setup like Branson where the engine is still mechanically controlled?
/ T654 emissions system #2
From what I can find online that the 2.9 L Deutz engine uses a Diesel Oxidation Catalyst (DOC), but it also states that a DPF is optional. I do not know which route TYM went with. My guess would be DOC.
Thanks for taking a look. I guess the surest way to know is to get in touch with a dealer and see if they can find out details. Will update here if I find anything out.
/ T654 emissions system #4
I am sure that T654 with Deutz engine has a DOC like Btown said, but a DPF is not optional.
/ T654 emissions system #5
I recently found this, it appears the use the DOC for Tier IV. When you add the DPF it meets the upcoming European standards.
/ T654 emissions system #6
Similar technology to what Mahindra uses...high pressure common rail, computer controlled injection, exhaust gas recirculation, and DOC. The DOC functions the same way as a catalytic converter for a gas engine.
/ T654 emissions system #7
Mahindra and others.
2013 Ram 5500 (A64127)
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Onan 6500 Generator (A66408)
Onan 6500...
