$!#& Chain Hooks
/ $!#& Chain Hooks
Something quicker, stronger than using mousing wire is to find the right size shackle for the hook. Leave it on the chain.
Everything is correct size and purpose of this thread is to find solutions on use and not necessarily go out and buy all new hardware when what I have "almost works"...
Dale
/ $!#& Chain Hooks #42
I'm sorry I wasn't clear. A shackle, of the right size for the grab hook, will be able to go where the mouse wire would.
So the only addition would be a shackle.
Electric tape, baler twine, wire are usually simple enough for when gravity can't be trusted.
Dale please try not to hurt yourself or someone else.
/ $!#& Chain Hooks #43
FarmWrench, could you post a link to, or pic of, the type of shackle you mean?
/ $!#& Chain Hooks #44
Same, have them on most all my chains. Ken's Bolt on Grab Hooks <<Accessories>> is a site sponsor I believe. Those clips can be a pain at times to latch or inlatch, but better than than things falling off.
Thanks for the mention, yes we have four different style of Twist-Lock grab and slip hooks in stock, plus many other handy accessories.
/ $!#& Chain Hooks #45
All my experiences with latching hooks have been the latch assembly gets bent up and become worthless and latch assembly has to be removed or constantly repaired... Your experiences may be different...
Dale
That absolutely WILL NOT happen with the Twist-Lock grab and slip hooks we sell.
/ $!#& Chain Hooks #46
/ $!#& Chain Hooks #47
Have to disagree slightly. I managed to mangle 1 if my slip hooks. It was rubbing on either my brush guard or another hook when tightened down a while back. If I recall I had to undo the bolt to get it off. I still use it although the latch doesnt latch. Probably will get around to unbending it and maybe rewarding the one side here one of these days. Still way more sturdy than the flimsy ones.
Have around 4 slip & 4 grabber hooks of various sizes. A bit of a pain to operate, but no worse than the flimsy ones & better than them falling off with no retaining mechinism. I'd get more, but they seem to be sturdy & not likely to need replacement.20180818_180426.jpeg20180818_180401.jpeg20180818_180358.jpeg
/ $!#& Chain Hooks #48
You broke Tonka toys as a kid right? :laughing:
That's the first one I've ever seen bent like that!
/ $!#& Chain Hooks #49
Ya, it's pretty stout. Ratchet binders can apply a pretty hefty load & getting pulled sideways on just the latch is targeting the weak spot. I'm actually usually pretty easy on mechanical things & always have been. :p
/ $!#& Chain Hooks
THis was hole point of this tread.... last thing I want is to get hurt and someone else to get hurt....
Have see one chain come loose and leave tracks in tailgate of PU truck... Its enough to make one what to be very sure that chains stay where they are supposed to....
Dale
/ $!#& Chain Hooks #52
I have found that having a grab hook mounted on my bucket is the best remedy for hooks coming off.
As far as slip hooks with bent up clips yes i still have them but i do have many that still do work. The bent ones got bent draging logs out of the woods.
They do make a better slip hook with keeper. The end of the hook fits into a notch on the latch to keep it from getting bent to the side.
Indusco 474:(1 Grade 8 Drop Forged Alloy Steel Clevis Sling Hook with Latch, Painted Finish, 3/8" Trade, 71 lbs Working Load Limit: Grab Hooks: Amazon.com: Industrial & Scientific
/ $!#& Chain Hooks #53
If one is relying on outer tip of hook.... Keep off my property....
Wire only keeps hook in place till one can bring tension on chain/hook...
Dale
Not a bad idea. Did you run the wire through the chain loop or just across the hook?
/ $!#& Chain Hooks #54
Truthfully, messing with the mousing wire is more of a PITA than getting off the machine in my opinion. Also crooked little pieces of wire that you can't find when you drop them and they can end up in a tire.
The biggest PITA is those locking hooks on the safety chains! I get it, it's a good idea, but not for casual use. It's like a two handed operation without gloves.
/ $!#& Chain Hooks
IN picture on bench setup I was not very careful and wire went through the chain link, my error in picture composition.... In field the chain is properly seated in hook and wire (mousing- term learned later) is merely across opening of hook to keep hook and chain from departing company before I can get tension on it to "lock" things in.... All things considered if chain is not seated in base of hook slot and under tension there is always chance it will not hold....
Dale
/ $!#& Chain Hooks
Yeah, but I getting old and body takes beating and any extra times I need to get off and back on tractor just makes my body hurt more (thank you Aleve) and raises frustration factor... Just want to do "hook up" once, not two or three time for each change in work operation... Monkeying (mousing) with a simple piece of wire (granted bent up) saves me a lot of pain and frustration...
Funny the safety chain hooks on my tandem axle car carrier with the spring clips are best ever I have run into BUT it's also on how they are "located" and used....
Yes they are somewhat different than what I would consider as "rigging" hooks...
Dale
/ $!#& Chain Hooks
Yeah, but I getting old and body takes beating and any extra times I need to get off and back on tractor just makes my body hurt more (thank you Aleve) and raises frustration factor... Just want to do "hook up" once, not two or three time fro each change in work operation... Monkeying (mousing) with a simple piece of wire (granted bent up) saves me a lot of pain and frustration...
/ $!#& Chain Hooks #58
/ $!#& Chain Hooks #59
Re: $!#&amp; Chain Hooks
It's a trade off. Sometimes I'd rather take my chances with climbing a ladder to put a cable on a tree, rather than cutting it without one. With some trees, unless one wants to hire a professional with climbing gear, a cherry picker or a crane and cut it from top down, a cable and a good winch lets you put that tree where it needs to go when gravity wants it somewhere else.
No need to climb. After fooling with throwing 3/4 drive sockets and twine or climbing a ladder (28 footer not high enough to get a good pull on a tall tree) I watched an arborist use one of these. I also helped him a little and used it myself. I bought one the next day. He showed me to tie a little knot about 8" from the weight. Then you spin it around and let loose of the knot. It goes really high and far. The string included is special, tightly braided to slide through bark and stuff. I was considering buying a kids bow and arrow to try as well, but the throw bag works like a dream.download.jpeg
/ $!#& Chain Hooks #60
No need to climb. After fooling with throwing 3/4 drive sockets and twine or climbing a ladder (28 footer not high enough to get a good pull on a tall tree) I watched an arborist use one of these. I also helped him a little and used it myself. I bought one the next day. He showed me to tie a little knot about 8" from the weight. Then you spin it around and let loose of the knot. It goes really high and far. The string included is special, tightly braided to slide through bark and stuff. I was considering buying a kids bow and arrow to try as well, but the throw bag works like a dream.View attachment 567942
Yep, yet another thing I've used during my illustrious Naval career, a BOLO.
Basically (Navy-wise) a small rectangular canvass bag (no bigger than a multi-tool pouch) weighted with lead with a grommet hole at one end. We'd use a LOT of parachute cord, coiled in an old coffee-grounds can, with one end tied to the BOLO (with a bowline knot). Throwing it as tjkubota93 describes to either another ship or to a jetty party.
You could then attach progressively larger diameter ropes (bowline to bowline or sheet-bend) to be passed to the receiving ship/party.
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Rhodes...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2013 PETERBILT 365(INOPERABLE) (A65643)
2013 PETERBILT...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
NEW Wolverine 78" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 78"...
