Aug 17, 2018 / How much do these wheel weights weigh #1 J jcummins Veteran Member Joined Jan 14, 2007 Messages 1,640 Location Creal Springs, IL Tractor Kubota M7040, F3680, Mule Pro Fxt This weight is on a 16.9-24 R4 tire. Has 512 stamped on it.
Aug 17, 2018 / How much do these wheel weights weigh #2 ovrszd Epic Contributor Joined May 27, 2006 Messages 33,727 Location Missouri Tractor Kubota M9540, Ford 3910FWD, Ford 555A, JD2210 I don't think it would weigh that much. But hard to tell by the pic.
Aug 17, 2018 / How much do these wheel weights weigh #3 S SDT Veteran Member Joined May 13, 2005 Messages 1,838 Location SE Indiana Tractor Multiple Fords and Kubotas jcummins said: This weight is on a 16.9-24 R4 tire. Has 512 stamped on it.View attachment 567252 Click to expand... Without going outside to check, those look like the weights on my L6060. IIRC, mine are around 100 Lbs. each. Dean
Aug 17, 2018 / How much do these wheel weights weigh #4 LouNY Super Star Member Joined Jul 4, 2015 Messages 14,836 Location Greenwich, NY Tractor Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH If these measurements are correct 100# 3157-1 Wheel Weights For Tractors - 10 Weights Weighing 1050 Lbs.
Aug 18, 2018 / How much do these wheel weights weigh #5 kuboman Veteran Member Joined Dec 5, 2009 Messages 2,304 Location Canada Tractor B3200, L5740, I think they are 165#.
Aug 18, 2018 / How much do these wheel weights weigh #6 dnw64 Veteran Member Joined Feb 13, 2017 Messages 1,906 Location SE Vermont, South Jersey Tractor Kubota B3030 Cab 512 hectograms = ~113#
Aug 18, 2018 / How much do these wheel weights weigh Thread Starter #7 OP J jcummins Veteran Member Joined Jan 14, 2007 Messages 1,640 Location Creal Springs, IL Tractor Kubota M7040, F3680, Mule Pro Fxt Ah ha...someone knows what the 512 means.
